94-95 ACCORD MANUAL TRANSMISSION
Old Apr 4, 2011 | 11:14 AM
lanenalinda27pr's Avatar
Default 94-95 ACCORD MANUAL TRANSMISSION
My car is in neutral. The passenger tire (which is the one that moves the car) moves but the driver side tire moves to a certain point and then locks. Does anyone know what this could be? has a new clutch
Old Apr 4, 2011 | 02:34 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: 94-95 ACCORD MANUAL TRANSMISSION
Both wheels move the car, there is a differential that differentiates the power when going around corners or if there is a loss of traction the wheel with less traction will spin.
As for the wheel locking, is it from something interfering with the wheel/brakes or is it differntial related?
Does the car not move in any direction? Are you sure you have all the linkages reconnected after the clutch install? How are you observing this issue? If there is more resistance on one side then power will be diverted to the other side. Be careful of doing this, as the wheel will be spinning twice as fast as indicated on the speedometer.
Marko Å plajt
Mar 21, 2019 05:07 AM
lkahawaii
Sep 16, 2014 07:00 PM
dan_g
Apr 5, 2013 11:38 AM
Gvis420
Nov 4, 2009 01:44 PM
JWEITEN
Feb 2, 2006 06:55 AM
