A/C Removed how can i get some cool air
Old Apr 4, 2011 | 10:34 AM
dem0nk1d's Avatar
Default A/C Removed how can i get some cool air
So I bought a 95 civic a few months back, and thought that all I need with the a/c belt to get the system up and running, man was I wrong. It seems like the seller just shoved the system back into the car, and said it would work of course. So once with the new belt on, I got no cold air, so I thought I would try a recharge kit, no luck with that either as the coolant was leaking out from old o-rings. So I got fed up and pulled the whole system out up to the firewall. I want to know if anyone has an tricks on increasing the outside air flow. To try to keep the car somewhat cooler.
Old Apr 4, 2011 | 11:36 AM
frankenghia's Avatar
Default Re: A/C Removed how can i get some cool air
You have to use the 2-80 air system. 2 windows down at 80 mph!!!! No seriously though, I have never seen or heard of anything for what you are asking for. Post up if you find something however....
Old Apr 4, 2011 | 11:47 AM
dem0nk1d's Avatar
sounds like i should rig up ram air vent for max fresh air.
Old Apr 4, 2011 | 11:48 AM
civicsmoke's Avatar
mini fan for your dash or windows down like said. If you've still got the A/C parts you could install them back into the car, the orings and seals are pretty cheap.
Old Apr 4, 2011 | 11:50 AM
civicsmoke's Avatar
http://www.beebuyer.com/p_images/t20...ce7917ea2d.jpg
no idea if it works lol
Old Apr 4, 2011 | 12:16 PM
dem0nk1d's Avatar
you are kidding. LMAO! i might as well have one of these mounted in the window.
Old Apr 4, 2011 | 12:46 PM
I FOUND A SOLUTION TO YOUR A/C PROBLEM!!!! LMFAO!!!!
Old Apr 4, 2011 | 12:53 PM
TunerN00b's Avatar
If that's too "ricer" for you, duct from the base of the windshield (high pressure area) into the cabin through the firewall.
Old Apr 4, 2011 | 01:05 PM
dem0nk1d's Avatar
so far it looks like there is no solution with out pulling an epic failure. guess once i get all new ac lines I'll attempt to reinstall the AC system
Old Apr 4, 2011 | 05:32 PM
fcm's Avatar
fcm
Old Fart
ROFL, we have that poster up on our wall at the shop, the caption on the bottom, missing on your link, is "THERE FIXED"...
http://www.airwolfeautoair.com/index.html
OP, you could increase airflow a little by removing the evaporator, you said you removed everything up to the firewall, so the evap. is still in place.
But the proper way, and only way to get "cold" air is to reinstall the A/C system, however, if you used a "refill kit" like Red Tek or Duracool You have contaminated the system with hydrocarbons and most likely sealers, no A/C shop will work on the system now, you would have to replace everything, unless you can find a shop with contaminated gauges and a contaminated vacuum pump.
You would still have to flush all the lines and components, replace the filter/dryer, [you should do that anyway] replace all O rings and seals, install the correct amount of A/C oil, [Ester oil] have the system pressure checked, [200PSI nitrogen for at least 1 hr, then have system evacuated for 45 min. to 1 hr and then recharged with R134a refrigerant.
Unless you replace everything, the system will still be contaminated with HCs, the sealants will be gone, but an identifier will still pick up the HC and as mentioned if the shop does not have contaminated equipment they can use, no percentage of HC is acceptable. 94
Old Apr 5, 2011 | 06:55 AM
dem0nk1d's Avatar
Thanks for the info. Hardcore!
Old Apr 5, 2011 | 09:20 PM
uberEFtuner's Avatar
What is the use for the car? Is it a daily driver, or race car?
I,m looking into a cool suit for my race car. I,m thinking of installing the system into the seats. Also thinking about using a front mounted cooler instead of ice.
http://www.ioportracing.com/Merchant...Category_Code=
Old Apr 6, 2011 | 06:34 AM
dem0nk1d's Avatar
Daily driver, so I can't be looking like TRON. But good idea for a track car.
Benjamin Allan
Honda Civic (2006 - 2015)
Jul 3, 2018 05:43 AM
albertewinters
Jul 23, 2014 05:21 AM
budget
Apr 14, 2005 08:13 PM
integra dave
Jun 2, 2004 01:20 PM
