Trailing Arm Question
Old Apr 3, 2011 | 10:21 PM
96Formula6spd's Avatar
Default Trailing Arm Question
Hey guys I need to get some new trailing arms for my crx. The car had ebay crap on it and the bushings are gone. Anways I don't want to spend any more money on this pos but I have to to get it out of my yard so I want to hit the junkyard. There are no crxs in the yard at the moment so would and ef sedan or ef hatch trailing arm be the same length?
Old Apr 3, 2011 | 10:24 PM
blue91EF's Avatar
Default Re: Trailing Arm Question
i do believe 90-93 integra NON GSR, 88-91 civic hatch or crx are almost identical and a perfect swap.
look for a hatchy IMO or a teggy & do the rear disc swap wile youre at it.
Old Apr 3, 2011 | 11:09 PM
d16efsedan's Avatar
https://honda-tech.com/forums/suspension-brakes-54/rear-trailing-arm-bushing-rta-part-number-1960010/
Old Apr 3, 2011 | 11:47 PM
hatchet_honda's Avatar
just replace the bushings in the trailing arms you have....done. go to honda or a parts sto' say hey! i need new TA bushings man!
Old Apr 4, 2011 | 09:07 AM
asianflava's Avatar
Just to clear up any confusion, the "trailing arm" is the part that the hub is attached to. It sounds like you are talking about the Lower Control Arm. The only "Ebay crap" I've seen are LCAs, the trailing arms are usually OEM.
If you are indeed talking about the trailing arm, just replace the bushing. These are 20+ year old cars, the rubber is expected to need replacing. You'll have the same problem if you find a junkyard part.
Old Apr 4, 2011 | 11:56 AM
Yeah the trailing arms are the top one. My lower control arms are stock but in really bad shape. The trailing arms are a very cheap set of and ebay camber kit. I went to the auto store and I can't use new bushings on this ebay trailing arm kit. Ones at the junk yard wore in pretty bad shape but expected. Going to order new ones.
Old Apr 4, 2011 | 08:10 PM
asianflava's Avatar
Those are not "trailing arms" that is the upper arm, or camber link. The one in the front is the compensator arm or toe link. The trailing arm is the whole stamped piece that runs front to back, which is why it trails behind. The hub and brake are bolted directly to it.
Post up in the WTB section that you need an upper arm. That way people know what you are talking about and you will get what you need. Either that or just buy a new camber kit, not all of them on ebay are junk. Get a Hardrace, Wicked Tuning, or SPC and you'll be fine. Just remember, you get what you pay for.
Old Apr 4, 2011 | 08:57 PM
yeah already ordered a new set. I bought the car with the crappy ebay camber kit and coilovers. Most dangerous car I ever drove. Hopefully with the stock suspension back in it can be drivable once again. Stupid cheap ebay parts.
Stan L Harding
Apr 18, 2019 07:50 AM
sackdz
Mar 19, 2005 10:06 AM
yOnKiNaToR
Jan 9, 2005 03:28 PM
raene
Feb 3, 2004 01:20 PM
sleeperCRX
Sep 25, 2001 07:35 AM
