91 si hatch runs about 10 min dies no spark
Old Apr 3, 2011 | 08:29 PM
fbcfab's Avatar
Default 91 si hatch runs about 10 min dies no spark
has anyone had this problem the car has new fuel filter and main relay and coil. car will run a little while dies and will only crank if i let it set awhile it will start and run for awhile and it dies any ideas
Old Apr 4, 2011 | 12:02 PM
fbcfab's Avatar
Default Re: 91 si hatch runs about 10 min dies no spark
come on guys i know someone has to have an idea
Old Apr 4, 2011 | 12:13 PM
milkmanLCA's Avatar
are you assuming no spark or did you check? check your fuel pressure as well. possible pump.
efjones9's Avatar
coil is bad. it heats up then cant generate spark due to the metal of the coil expanding and losing contact some how, short solution, replace the coil in the distributor
Old Apr 4, 2011 | 12:18 PM
.Manny.'s Avatar
Touching My Member
The igniter will do the same. get hot and quit.
Old Apr 4, 2011 | 12:21 PM
efjones9's Avatar
correct also
Old Apr 4, 2011 | 02:38 PM
1990edsedan's Avatar
Replace the dizzy. Problem solved. If the igniter is on it's way out, you can bet the coil will follow.
Old Apr 4, 2011 | 05:15 PM
fbcfab's Avatar
hey thanks guys i already changed the coil and it did the same thing so im going to change the ignitor
Old Apr 5, 2011 | 05:36 AM
And replace the cheap O ring on the end of the dizzy while you are at it.
Old Apr 5, 2011 | 07:57 AM
90efhatch's Avatar
^^ I would check this.
Old Apr 5, 2011 | 09:16 AM
rcoolb2002's Avatar
Its the ignitor. Just had to replace it on mine.
C-REX 88
Feb 27, 2010 06:18 PM
NL826
15
Jan 23, 2010 12:22 PM
jdmDAsix
May 17, 2004 01:43 PM
JTCdudeman
Nov 22, 2003 10:37 PM
havok hybrid
Aug 27, 2002 12:53 AM
