95 Civic EX hesitates and speedometer doesn't work
I have a 1995 honda civic ex auto, everything is stock on it...The problem I have been having is that the rmp's will drop however the car wont die, it just slows down and then picks back up to speed...It seems to do it more when I'm going slow around 25 mph... Another thing is that it seems to do it when my speed ometer isnt working... I have replaced the tps and have recently done a tune up...So anyone who thinks they may know the problem please write back...Thanks
Any CEL?
Speedometer sensor??? A buddy of mine has a 94 accord ex and when his speedo sensor went bad he says it made the car run like ****, ive never had one go bad on me...and if your speedometer isnt working than neither is your vtec.
Does it surge while you are accelerating?
Have you replaced the distributor cap/rotor?
No I have not replaced my fuel filter or my distributer....My car just feels like I let off the gas when I don't then after like three secs. it will pick up to speed again...
Let me know if you find a solution, My '95 Civic is acting similar (my speedometer is working fine though). My car acts as you described for a bit, then the Check Engine light comes on, then it runs fine until the Check engine light shuts off.
Try cleaning out the throttle body. Buy a can of throttle body cleaner and follow the directions on the can. Thats what I did, and it fixed the problem with my car.
ASO
Transmission & Drivetrain
Feb 7, 2010 07:49 PM
