Pls help! Passenger window regulator is not working
I can operate this window from the driver's side, but passenger's switch is not working..I checked master lock - it is released.. Could that be a problem with fuse? (BTW, I own Civic Si 2004 coupe) Thanks!!
If the fuse was bad, the window wouldn't roll down no matter which switch you used.
The problem is likely the passenger window switch. Either it's unplugged, has a bad connection, or the switch is bad and needs to be replaced.
jerBEAR
Honda Civic (2001 - 2005)
Sep 6, 2010 06:11 PM
BauleyCivic
May 1, 2005 04:42 PM
