MA FS: 1996 civic dx pros/cons
well up for sale is a 1996 civic dx coupe 5 speed MT
i have owned the car for about three years but can no longer put money into it and have no real use for it even though i love it! just became a father so here goes.
car: see above
price : 2000$ FIRM CASH ONLY.
cond : Runs fine no plates ect with car.
so heres everything done to the car. keep in mind it was used in SCCA sanctioned auto cross in Georgia.
engine/drivetrain :
Engine is internally stock.
Clutchamsters stage 1 fx100 clutch and Fidanza light wight flywheel.
ebay short throw shifter (single bend) never failed me yet.
Energy suspension hard mount shifter bushing kit.
recently flushed and changed Gear fluid with Honda spec fluid.
axle back 2.5" custom exhaust.
Suspension/braking:
Brembo blank rotors up front.
Hawk HPS performance brake pads in front.
DOT-4 fluid in entire brake system. was fully flushed.
drums stock in rear.
Koni "yellow" sport shocks fully adjustable. (non race valved)
Ground Control coil over system 375 pound springs up front 425 in rear.
Front Ground Control top-hats to allow further shock travel.
No sway bars front or Rear. 22mm ITR bar spherical racing end links and mounts included with car.
Skunk2 pro series adjustable front upper control arms with polyurethane joint.
Moog polyurethane lower front ball joints.
replaced outer tie rods on each side OEM.
all lower control arm bushings are energy suspension polyurethane.
Rest of kit for rear ect comes with car.
Body:
front fenders are jdm spec with side markers from password.
front bumper is also new oem spec.
spoon style side mirrors.
rear EM1 civic si spoiler. (came on car) has built in brake light.
front knock off CTR grill.
Rear fenders are completely rolled for tire clearance.
SO thats all the good and as you can see it is intended for auto-cross use.
now the CONS:
windshield has a crack (below driver sight line)
interior headliner is completely gone. (was hanging so i just removed it all)
front drivers seat has a 3-4 inch tear.
Ignition to starter wire had failed and a pushbutton setup is now installed.
windshield wiper fluid system has been completely removed.
AC system has been completely removed.
Needs new heater coil.
driver + passenger door panels are cracked.
horn has been removed (before i owned car)
roof has a big dip in it.
antenna for radio removed (block off plate used)
hood has some dips and has had some body work done.
front end is slightly off and needs alignment.
both headlight housings have damage in the back (both still work)
bank 2 02 sensor throws ECL ( i have new one in box with car)
some waves down side of car. some of car is primer see photos.
FYI foglights are now hooked up i know in pics they are not.
car: see above
engine/drivetrain :
Suspension/braking:
Body:
now the CONS:
WSG_buBble
Jun 21, 2007 04:55 AM
X2BOARD
16
Dec 16, 2004 07:04 AM
ActiveAero
13
Apr 8, 2004 01:49 PM
