96-98 sir replica lip install
Old Apr 2, 2011 | 10:50 PM
jdmpassword562's Avatar
Default 96-98 sir replica lip install
i need help installing my sir lip for my coupe asap
Old Apr 2, 2011 | 11:38 PM
BC_Garage's Avatar
Default Re: 96-98 sir replica lip install
Does it use the the clips that slide into the factory mounting points underneath the bumper or does it screw on the back of the bumper near the wheel well?
Old Apr 3, 2011 | 12:08 AM
98civdx's Avatar
Master Detailer
^ To my knowledge, no they do not.
Only the OEM lips do.
How the lip fit the bumper? Most aftermarket lips are simply screwed onto the bumper.
But this might be a problem with a SIR.
Can't compare it to much, but my OEM sir lip would be impossible to mount that way.
Old Apr 3, 2011 | 01:37 PM
way different from the oem lip and aftermarket typr r/mugen
Old Apr 3, 2011 | 02:02 PM
98civdx's Avatar
Master Detailer
if you haven't figured it out already, take some pics. I would be able to help more if i could see what your working with.
Old Apr 3, 2011 | 04:24 PM
Old Apr 3, 2011 | 04:25 PM
help....
Old Apr 3, 2011 | 04:52 PM
98civdx's Avatar
Master Detailer
Why the lip look bent, almost forming a circle?
Your going to have use those plates. Line it up on the bumper where you want it, and snap some a pic of it.
I would do my best to keep everything under the lip, so you see noithing.
Old Apr 3, 2011 | 05:08 PM
grumblemarc's Avatar
The Grumpiest
Probably was shipped folded up in the box.
Old Apr 3, 2011 | 06:05 PM
98greensi's Avatar
go to a autobody shop give them the lip car and pic of what it's suppose to look like.
it's pretty straight forward but if u cant figure it out, i would recommend it.
but, put the lip where u want it, then take the mounting plates put a screw into the bumper and one into the lip from the bottom. evenly space them out so hopefully the lip dose not sag
3 in the middle some where and the other 2 somewhere towards the sides, u can use 10 screws or 5 pop rivets (requires pop rivet gun) and 5 screws
Old Apr 3, 2011 | 10:24 PM
eksedan98's Avatar
I would take the bumper off the car and line it up with the lip. Use some double sided tape to keep the lip onto the bumper while you drill the screws onto the lip. Hope this link helps.
http://www.b20vtec.com/forums/detail...p-install.html
EJ8Bramaged
Nov 16, 2009 12:04 PM
SlammedEH3
Jun 16, 2009 12:33 PM
icefirezero
Jul 15, 2006 01:42 PM
Daniel
Dec 6, 2002 05:01 PM
