testing lock up solenoid valve A/B
Old Apr 2, 2011 | 06:46 PM
cavrdave's Avatar
Default testing lock up solenoid valve A/B
The service manual says to 1.) Check the resistance between pin 1 and pin 2 and verify it's resistance is between 12-24 ohms, 2.) check the solenoid from the positive battery terminal to pin 1 then pin 2 to see if it clicks which indicates it's working.
I do not get a resistance reading but it does click. Is there a reason why they tell you check the resistance first? Thanx!
Old Apr 2, 2011 | 06:50 PM
phootbag's Avatar
Default Re: testing lock up solenoid valve A/B
Ohm pin 1 to ground. Ohm pin 2 to ground.
90civicstdgold
Mar 12, 2010 01:33 PM
krispyaccord
Sep 12, 2005 02:07 PM
98AccordEX
Feb 23, 2003 01:38 PM
