Removed a pump on washer fluid resevoir now horn doesnt work
I would check fuses first. If they're on the same fuse it could've shorted out... I took my reservoir completely out and my horn still works. Good luck with it and let us know when you figure it out.
which wire on this diagram would be classified as the horn ground ?
http://i267.photobucket.com/albums/i...cture_3401.jpg
bhillier
Mar 3, 2009 01:12 PM
