EG trans in EK what mounts?
I got a 1998 Civic Ex Auto. I got pedals from a 98 car. Trans, Starter, Flywheel&Clutch, shifter came from a 93.
So I'm mating a B000 P20 trans to a D16Y8 in my 98 Civic. I got all the trans mounts and brackets off the 93, but will these work in my 98? If not what do I need.
Huge Thanks!
-Ryan
Huge Thanks!
-Ryan
You need the upper and rear brackets from a '96 - '00. The automatic rubber mounts you have will work, however they aren't as strong as the manual version. I have a couple of the upper brackets in my F/S thread (link in bottom of post) btw if you can't find one locally.
Thanks. I got the entire rear mount off a 96 so I'm good there. So on the upper mount I need the frame side right? Not the trans side.
I'm not worried about the weaker mount right now b/c when I turbo it I'm going to go to urethane mounts. Right now I just want to get it going.
Thanks,
Ryan
Thanks,
Ryan
I think I'm ready to swap the trans, except for that upper mount. I'm going to a yard tomorrow to see if they have not. If not, I might be contacting you 94EG8.
I swapped the clutch pedal in already, no problems there. Also Swapped in the manual brake pedal, but just the pedal. This way way easier, took me 30 min and didn't have to disconnect any electrical connections.
Looking forward to shifting gears again!
vartok
Nov 13, 2011 12:48 PM
thehybridkid
May 27, 2004 08:35 AM
