Help Honda-tech on my build
Hey ht doing a lsvtec turbo build and want to kno if
I can get 400 450 up out of my set up any input well be help
fo here it gozzz
b18b1 block 81.5 mm bor
crank ls micro polish
Golding eagle rods
wiseco pistons 8.8-9.0
Golding eagle lsvtec conversion
arp head studs
rod bearing
head b17a1 head same as b16
hondata intake manifold gasget
ether blox or victor x intake manifold
skunk2 throttle body 68 mm
ferrea valves springs and retainers
toda killer cam
aem or skunk2 cam gears
toda timeing belt
grs or type r water pump and oilpump
walbro 255 fuelpump
aem fuel rail
Golding eagle block garde
CxRacing turbo kit cast manifold
any help would be good on my build and wat kind of et
times u guys think I can hit oo and it's going in a db2
BuMp this thread Up
fo here it gozzz
Golding eagle rods
arp head studs
rod bearing
toda killer cam
toda timeing belt
walbro 255 fuelpump
aem fuel rail
BuMp this thread Up
So you posted your AEM fuel rail and then didn't post what you'll be tuned on, what size turbo, and what size injectors.
Nope, you're not making that horsepower.
so you'll shell out $1500 for useless cams for your application... but only spend $700 on an ebay turbo kit.... doesn't make any sense IMO... https://honda-tech.com/forums/showth...ec+turbo+thead start here and do research on what you NEED, and what will WORK.
