throddle body sensor adjustment help?
Old Apr 2, 2011 | 09:45 AM
PetersonJ39's Avatar
Default throddle body sensor adjustment help?
I just replaced the tps on my crx with a zc swap and cleaned the throddle body while i had it off put all back to the way it was with the new sensor and took it for a test drive and it worked exept for at low low rpms, i noticed that the sensor had adjustable screw slots does that richen and lean it out if i turn it either way
Now today i drove it worked good for about 20 minutes and then threw a cel and started acting up again, it feels like the car is flooding out when i take off and has little power under 3 grand cuts out and wants to die?
if you could help me out that would be great
Old Apr 2, 2011 | 10:17 AM
.Manny.'s Avatar
Touching My Member
Default Re: throddle body sensor adjustment help?
Timing off?
Old Apr 3, 2011 | 06:54 PM
SoCal92071's Avatar
Old Apr 3, 2011 | 06:59 PM
SoCal92071's Avatar
I had the same happen to me it started great and ran great till it warmed up and then ran like **** wouldn't go over 3grand and wanted to die. Found out it was bad wires. So I would start there.
Old Apr 3, 2011 | 10:38 PM
~sp33~'s Avatar
EFB055
Check this thread.
https://honda-tech.com/forums/showth...&highlight=Tps
BakktoJDM
Honda Civic (2001 - 2005)
Apr 24, 2009 06:26 PM
deucedeuceEK
Apr 27, 2007 02:39 PM
95_red_dc
May 5, 2006 08:52 PM
95_red_dc
May 5, 2006 06:39 PM
88crxhfb16
Nov 15, 2005 12:22 PM
