Multiple help issues.
ok, if any of you guys can answer a couple questions for me that would be great.
I have a 96 coupe (EX) with a d16y7 (95 block) and a d16 vtech head. It idles (rough) and runs worse over 3500 rpm. I am wondering if the issue could be the 95 block not having the crank position sensor and the ecu looking for one. Any ideas?
question two....I have an h22 in a 95 hatch. Will the axles fit from the eg into the ek if I decide to swap the 22 into the ek?
I am sure I am missing some info but any help would be awesome.
Issue #1. Any CELS? Check timing?
Issue #2. Move the COMPLETE swap, including axles, to the EK. If you did the H swap you would know those are not any axles from any D-series.
I did not do the swap and am aware the axles are not from a d series. I bought the hatch that way and am wondering if the axles are universal between the eg and ek.
No cel right now and checked out the timing a little. Just wondering about the crank sensor as of right now. Any info on that? block is obd1 and car/ecu/head are obd2.
IF you know the axles are not from a D-series then why are you asking if axles from a D-series will fit? No. All Honda axles are NOT universal. And if I remember correctly when you move the swap to the EK you will have to do some cutting/fabbing. It's not a drop in swap.
What do you mean you checked the timing out a little? I wasn't aware they made a Y7 in 95.
my bad. I don't think I explained this well enough. I have two cars. a 95 hatch w/ a h22 and a 96 ex coupe with the d16. I want to take the 22 out of the eg and put it in the ek. My question is will those axles work in the ek?
Yes it will. I think I said that. You will still have to do some cutting to get it in. Like I said it is NOT a drop in swap.
If you're doing the swap then why worry about the other car and it's idle problems?
Read this on what's entailed in the swap.
http://shockerboys.20.forumer.com/viewtopic.php?t=96
SoySauc3 H22atch
Nov 16, 2005 08:52 AM
