FS/FT: 96 Civic Coupe Part Out - Ohio
As of 11/5/2011 I've updated all the pictures/groupings and lowered prices on some parts. Hopefully this cleans up the posting a bit and makes it easier to read.
[All prices are best offer and available for pickup (preferred) on the eastside of Cincinnati. Shipping is also available via USPS. I will try and get whatever items you are wanting into the USPS flat rate boxes to save on that. If it doesn't fit in a relatively normal box (The rear hatch trim for example), pickup will be the only option. Paypal (or cash if picking up) are the only methods of payment I'll accept.
The fastest way to get ahold of me is via email (whiteacclude@yahoo.com) or text (513-253-6660). I'm only on here relatively frequently, but not every day. Please do NOT text me anytime between 10pm and 7am... I'm old and need my sleep!
I will accept trades for 1998 Civic Hatchback parts. EMail/text me with any offers and please include pictures. If out of town, email me and we can work something out.
PLEASE READ CAREFULLY -- I am only listing those parts that I have available. IF its not listed, I don't have it. I will list parts sold on here as a bit of a vouch:
- Tweeters -- ** SOLD to cruizinmax **
- carpet -- ** SOLD to IHRTJDM**
- floor harness -- ** SOLD to B18eg6ICK**
- OEM radio/tape slave and CD changer -- ** SOLD to updhands**
- b-series cam gears -- ** wtf_is_jdm**
- y8 clutch kit -- ** SOLD to Honda_ek9**
- PAss side splash guard piece **SOLD TO 93CivicSedan**
ALL PRICES ARE BEST OFFER!!!!! I can't stress that enough.....
- Suspension Techniques 22mm rear sway Bar with endlinks and subframe bushings/brackets. Was toldit would fit a 96-00 Civic, but not a chance. Doesn't fit a 94 Integra either. I'm out of ideas - $50
- 96-00 OEM Honda front upper control arms ***SOLD LOCALLY***
- Rear Lower Tie Bar ***SOLD LOCALLY***
- 96-00 OEM Honda Civic rear LCAs. The hub mount bushings will need replaced - $15
- 96-00 Honda Civic front driver and passenger EX brake calipers. Came off a non-ABS Civic (not sure if that matters to those with ABS or not... buyer to determine). I will NOT separate the pair -- $30
- Working windshield wiper motor - ***SOLD LOCALLY***
- D16Y7 Alternator. ***SOLD LOCALLY***
- Honda Passport NON-WORKING alternator. Good for a core - $5
- (2) H22A OBD1 distributors. ***SOLD LOCALLY***
- d16y7 P2E manual ECU. ***SOLD LOCALLY***
- 96-00 Civic Interior fuse box with fuses and relays. - $12
- 96-98 Engine bay fuse box (Came from an EX/y8/5spd) bare - $5
- 96-98 Engine bay fuse box (Came from an EX/y8/5spd) with fuses/relays - $12
- Various switches/buttons; (1) hazard, (2) rear defrost. All in perfect working order. - $5 each or (2) for $8
- Honda Main Relay Switch. This should fit all model 1996-2000 Honda Civics however its the buyers duty to find out. Worked perfect when removed - $20
- F22 Accord non-vtec fuel injector resistor - $10
- Ebay CAI intake bypass valve; ***SOLD LOCALLY***
- 1996 Honda Civic Driver's side airbag. ***SOLD LOCALLY***
- 96-98 Civic SRS brain. Buyer to determine if it works on 99-00 Civics as well. Removed from car with no front end damage. - $20
- Rear view mirrior - $3
- 96-00 Civic Cluster bezel - $5
- d16y7 Clutch, pressure plate and flywheel. ***SOLD LOCALLY***
- d16y8 Postive battery cable and starter wire - $5
- d16y7, d16y8 and possibly other d16 motors, upper and lower radiator hoses. No rips, cracks or tears. Just replaced with new ones at the time of the swap. - $5
- 96-00 Civic (and possibly 92-95 Civics and 94-01 Integras) Edelbrock Short Shifter -- ***SOLD LOCALLY***
- 1996 Civic EX Cruise Control Unit. Worked when removed. May fit other makes (Integra?) and Models (Accord? CRV? Prelude?). It's the buyer's responsibility to find out compatibility. - $10
- 96-00 5spd clutch line that runs from clutch reservoir to the soft line behind the block - $5
- 96-00 5spd clutch line (soft and hard line) to the CLutch slave cylinder. Boot in good shape. Worked fine when I swapped in the y8/Tranny into my car. -- $15
- Various motor mounts from b18, d16y7, d16y8 and d16z6 motors/cars. Bolts will be included if they are shown with the mount. $5 each
- D16Y7 header heat shield. In good shape for its age. No busted bolt holes. Good candidate for a re-paint - $8
- 96-00 Civic Power Steering Reservoir and hoses ***SOLD LOCALLY***
- 96-00 DX/LX tranny flywheel cover - $10
- 1996 Honda Civic EX Brake Booster. ***SOLD LOCALLY***
- D16Y7 & D16Y8 OEM Honda oil pan. ***SOLD LOCALLY***
- Autometer Pro-Comp Air Fuel Gauge. ***SOLD LOCALLY***
- 96-00 OEM Honda front upper control arms***SOLD LOCALLY***
- BNIB Autometer gauge angler pod thingees - $5
(also have those sub box tubes pictured if someone is interested)
- Rear bumper foam/reinforcement -- JUNKED
- Windshield cowl with all snaps/buttons/thingamjigs. No cracks at all and in great shape - $15
- Rear dash/speaker cover/panel - $10
- driver and passenger side panels from a 96-98 Hatchback. May fit 99-00 hatches as well, but that is for the buyer to determine. Dark gray color. Normal wear but no significant scratches and no cracks. WILL NOT SHIP - $35
- Front undercar splash guard/wind panel. No tears. - $15
- 96-98 Coupe A-pillar plastics. ***SOLD****
- 96-98 Hatchback rear trunk trim (goes in the trunk portion of the car). May fit 99-00 Hatchbacks but that's for buyer to determine. - $5
- 96-98 Coupe rear trunk trim. -- JUNKED --
- 96-98 Rear Hatchback speaker covers. May fit 99-00 hatchbacks but for the buyer to determine. All clips present for the cargo cover. No cracks. Hard to find in this good of shape. Will not separate. - $30 for the pair.
- 96-00 Civic driver door window glass. ***SOLD LOCALLY***
- OEM 92-96 H22 oil pressure sending unit. Pulled this from a motor I built a few years ago. Worked fine when pulled, but removed to put in an Autometer oil pressure gauge. Might fit 97+ H22s, but up to the the buyer - $5
- () OEM Honda H22 tensioner stoppers, Honda P/N: 14540-P13-003. BNI-baggie. (used-once tensioner **(1) SOLD to an HT member**). - $5 each
- BNIB d16 Thermostat. Stant P/N: 13878. Does not include gasket (which is sold separate at any parts store). $8
- BNIB Beck/Arnley Distributor cap, P/N: 174 7007. **SOLD to an HT member**
- BNIB Airtrex electric in-tank fuel pump, p/n: E8335. Fits most Hondas, but click the Summit link below for more applications. Buyers duty to check fitment before purchase. - $50
More info and Summit Racing's price here: Airtex 110-E8335 - Airtex Electric In-Tank Fuel Pumps - Overview - SummitRacing.com
- BNIB Fel-Pro B18A, B18B cam shaft seals. $8
ALL PRICES ARE BEST OFFER -- Don't like a price, make me an offer. The worst I can say is no.
Last edited by mayfieldfour; Jul 27, 2012 at 04:17 PM. Reason: updated parts sold and available.
I was really confused for a second there... Glad it fit for you. LMK if you need anything else... still got some randomness there.
Interested in trades too. Email or text will get you a faster response!
Bump..... sold a moajority of the interior panel pieces. Email/Text me if you still need something in particular. I do still have both a-pillars, the dash, shirfter console, armrest "delete", lite gray armrest, rear deck piece and trunk trim.
PM'd. Shoot me back an email: whiteacclude@yahoo.com
It should, though its already sold. I'll update the thread.
PM'd back. Sorry about the cow incident...
All prices are negotiable. It's MUCH FASTER to email or text me as I'm not able to get on here every day. Contact info is in the first post.
Got it... they will ship out tomorrow. I'll email you the tracking number... Thanks!
Entire parts list and item groupings have been updated. Be sure to look over the entire first post as there have been some new items listed.
Open to all offers!!!!
^^^Appreciate the bump. Glad you got them and all is good. Thanks!!!
Floor harness and y8 injectors have been sold.
Make me an offer on the rest... need the stuff gone to start the build on my y8!
Thanks for the floor harness Nick! I just received it yesterday. This will make it much easier to put my power windows and doors in. Thanks again. BUMP and will recommend.!
