FEELING IT SLOW EM1
Old Apr 1, 2011 | 03:43 PM
EDWINV00SI's Avatar
Icon2 FEELING IT SLOW EM1
when i first bought my em1 i felt it pretty quick & the rpms will climb up quick now i feel it slow like if something is holding it back and rpms take longer to climb up. i just replaced my spark plugs, dist cap & rotor. still need to change spark plug wires and fuel filter. i have a bad 02 sensor that i need to replace is that the problem? is there anything else i need to replace?
Old Apr 1, 2011 | 03:47 PM
BryanM.'s Avatar
Resident Gearhead
Default Re: FEELING IT SLOW EM1
A bad 02 sensor can make it feel sluggish.
Alway start by fixing CEL codes.
Old Apr 1, 2011 | 03:51 PM
EDWINV00SI's Avatar
yeah thats how it feels bro but i wouldnt have thought it would make it that slow lol is there anything i need to look into?
Old Apr 1, 2011 | 06:49 PM
98civdx's Avatar
Master Detailer
Be carefull on the lower bolt on the fuel filter. They are very very well known for a being a PITA. It also is quite easy to round off.
I had so much trouble, I almost said F it. I ended up using a crows foot and that did the trick after about a hour of fighting it.
How many miles are on it? Is it burning oil? Loosing compression?
I agree with Mcvtec, fix the o2 first.
Old Apr 1, 2011 | 07:13 PM
es.roadster's Avatar
also throttle cable adjusting/tensioning would help.
over time they seem to stretch/slack.
check your vtec fluid aswell
Old Apr 1, 2011 | 07:31 PM
hyperblu's Avatar
lol @ vtec fluid
Old Apr 1, 2011 | 07:59 PM
lshatch98's Avatar
a line wrench works the best.
Old Apr 1, 2011 | 09:31 PM
EDWINV00SI's Avatar
Thnx for advice bro, my car has 97k miles & no its not burning oil only when i hit vtec lol
Ill check that thnx
Originally Posted by hyperblu
lol @ vtec fluid
I think he ment my oil frm the engine
Old Apr 2, 2011 | 12:27 AM
98civdx's Avatar
Master Detailer
Actually NO, they aren't always the best.
I woudn't have told him to use a crows foot unless it worked.
OP, that really isn't many miles at all. I am suprised to here you are haveing issues with such low miles.
I was going to say check the throttle cable, but forgot.
Good luck with getting this fixed.
Old Apr 2, 2011 | 03:10 AM
Kista20's Avatar
Actually they do work good. I have a set if wrenches that I've only used to change out the fuel filter and I never once had much of an issue with that lower bolt. The ones that I have are offset so you have to keep flipping the wrench over, yes it's a little time consuming but it works.
Since I've had my 97 I've replaced it about 4-5 times already and I also just replaced it on my 99. I have always used purolator fuel filters and never had any problems.
Old Apr 2, 2011 | 10:32 AM
98civdx's Avatar
Master Detailer
I never said they don't work well, what I said was they aren't always the best.
I tried every wrench I could find. ( My dad has TONS of wrenchs) Noithing worked. The last option was a crows foot which did the job.
I was only giving the OP another idea of what he could use, if he runs into the same problem I had.
OEM fuel filters here.
h_civ2000
35
Oct 20, 2009 04:15 PM
joaodossantos
Jun 9, 2007 08:18 PM
Ed 341
Jul 17, 2006 06:24 PM
tallguy
18
May 5, 2005 03:47 PM
AllMotor12s
May 25, 2004 06:50 AM
