b16 intake manifold vacuum hose
Old Apr 1, 2011 | 01:24 PM
kbear's Avatar
Default b16 intake manifold vacuum hose
i was wondering if anyone could help me out with where the vacuum line goes on the b16 manifold. if i leave it un plugged, the car runs and drives on 3 cylinders but if i plug it up the car dies. i have no idea where it goes. i was informed that this is an older model manifold and that the newer ones dont have this...not sure...its the vacuum that is located in the middle of the manifold.
here a picture of it. its the one with the blue hose coming out of it.
any help would be greatly appreciated!!!!!!!
Old Apr 1, 2011 | 01:58 PM
grumblemarc's Avatar
The Grumpiest
Default Re: b16 intake manifold vacuum hose
Can't find any B16 that looks like that. How long has it been this way? Where are you plugging this up to? When the car dies does it throw a CEL? Does it throw a CEL at any time the car is running?
Old Apr 1, 2011 | 06:47 PM
kbear's Avatar
well its a b16 intake manifold attached to a b16 head. the motor is acutally a ls/vtec motor and we just got done building it so i cant figure out where it goes. for now it just isnt plugged up. the car is throwing codes for vacuum leaks....anyone know where this is supposed to go?
Old Apr 1, 2011 | 07:06 PM
kbear's Avatar
it looks like a jdm b16a2 intake manifold
Old Apr 1, 2011 | 07:34 PM
hyperblu's Avatar
goes to intake tubing...
Old Apr 1, 2011 | 08:18 PM
shogee's Avatar
Probably for the purge solenoid
Old Apr 1, 2011 | 08:23 PM
B18C EG6's Avatar
Duz it not go to PCV valve onda manifold flange between two runners
Old Apr 1, 2011 | 09:55 PM
kbear's Avatar
not sure...some pictures on google showed that it connected to another valve on the intake mani under the fuel rail in between injectors....i guess ill try that tomorrow. lmk if you think it will go anywhere else!! thanks appreciate the help
Old Apr 1, 2011 | 10:57 PM
hatchet_honda's Avatar
top port goes to the brake booster hose. the blue hose id say def goes to the pcv valve. do you even have one hooked up? if you dont thats where the blue line goes
Old Apr 2, 2011 | 10:34 AM
kbear's Avatar
where is the pcv valve?
Old Apr 2, 2011 | 11:25 AM
kbear's Avatar
hmmm im guessing i dont have a pcv valve since i read that only vtec motors have them? i have a b16 head mounted onto a b18b block. i read that you have to drill a hole and attach a nipple to the back of the block and have a catch can in between? can anyone verify this?!
heres the link http://honda.hybrids.jp/b20tech/b20-pcv.shtml
Old Apr 2, 2011 | 01:33 PM
kbear's Avatar
hmmm i attached the blue hose to the valve cover and it does die as much...stayed running for a little then died once...
Old Apr 3, 2011 | 06:26 AM
Red_Army's Avatar
a b16 is a vtec motor. all motors have a pcv. you actually defined where its located about 5 posts up.
sounds like you started a project you never should have gotten into.
Old Apr 4, 2011 | 03:56 PM
kbear's Avatar
right all motors have a pcv but non vtec motors such as the b18 which i have has it on the valve cover. since i went ls/vtec b18/b16 i dont have a port any longer. therefore i dunno where it goes lol. you are right when you said i started a project i shouldnt have. haha i just connected it to the valve cover....works for now i guess
Old May 16, 2013 | 03:02 AM
antvtec1's Avatar
Can anyone give me a straight answer where this hose goes
Old May 16, 2013 | 03:57 AM
GroundX's Avatar
That's a EM1 intake. Tried to look at pictures of mine but couldn't see where it goes from the pictures.
Could it be to the IACV? (Not the one with the red ring, thats the purge and not where this connects )
I can give it a better chek when I arrives from home.
Old May 16, 2013 | 04:44 AM
93jdmb16aII's Avatar
I have the same manifold on my second Gen jdm b16a and it goes to the pcv valve under the fuel rail
Posted from Honda-tech.com App for Android
Old May 16, 2013 | 05:17 AM
kyden's Avatar
^^ yes. it goes to the pcv. the small nipple on the back towards the drivers side is for cruise control.
Old May 16, 2013 | 12:54 PM
GroundX's Avatar
Aaaah, I learned something there kyden thanks!
And I can now confirm that the hose goes to pcv under the fuelrail between cylinder 3 and 4
Old May 17, 2013 | 05:04 AM
antvtec1's Avatar
thanks alot lads helped me alot anyone else confused my b16a2 had a black connector coming up between the 1st arm of the inlet manifold mine looks like its snapped so will be running it straight threw the inlet on to the pcv box i can get pics if it helps. thank you lot again very helpfull. :D kbear whats that braided fuel hose you have got where did you get it from?
stevenDAtegra
May 28, 2009 03:10 PM
BodyKits NW
11
Jun 14, 2008 11:16 AM
blueEM1
Jan 4, 2006 04:05 PM
