98 integra RS troubles!! i need help
Old Apr 1, 2011 | 11:27 AM
myp1nkt3ggy's Avatar
Default 98 integra RS troubles!! i need help
hey Guys! i need help finding out what wrong with my dc. i changed the spark plugs, wires, and distributor. the car runs ok at first then it goes crazy and souds like its misfiring bad. then when im driving it goes to normal and then the check engine lights blinks and stays on. so i dont know what it could be. it never did this crap till i changed the plugs, wires, distributor and fuel filter. please can you guys help me?
Old Apr 1, 2011 | 02:33 PM
Default Please i need answers.
i really need help with this car. i had an ek hatch and that never gave me problem and now since i got an integra its giving me a headcahe. i need some ideas what it could be...
Old Apr 1, 2011 | 02:42 PM
sebTeggy's Avatar
Default Re: Please i need answers.
WTF?
How about telling us what the problem is. You basically just made a post complaining and not really saying anything haha. Thanks for the laugh.
Old Apr 1, 2011 | 02:51 PM
well it was the only way to get the attention. lol. well i just changed the spark plugs, wires and fuel filter. and all of a sudden it just starts acting funny and idling weird. when i take off driving it kicks in and drives normal then it throws a check engine light. i checked the engine light and it said cylinder 3 and 4 misfiring. but it never did this before i did the tune up. so i dont know what it could be.
Old Apr 1, 2011 | 03:47 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: 98 integra RS troubles!! i need help
Threads merged. You can't expect answers immediately. Don't make another thread with the same question only 3 hours after the first one just because you didn't get any replies in that time.
First things first, figure out what trouble code you're getting from the check engine light. If you don't have a scanner, most any auto parts store will scan and get the code(s) for you.
Also just double check to make sure all the stuff you installed is installed correctly and completely.
JENNY_EG6's Avatar
Were any of your fuel injector wires cut before? or any fuel related harness? I've had the same problem before, rewired my injector clips and plugged everything back in again and car ran smooth. Try checking the connecters or maybe the spark plug wire orders, sometimes people forgets these dumb little mistakes
Old Apr 1, 2011 | 04:05 PM
Laserjock's Avatar
It's your typing skills they suck.
Check the firing order. And then work on your typing skills cause they suck.
Old Apr 1, 2011 | 06:16 PM
mark@silbernage's Avatar
It's a pretty good technique, when you want to troubleshoot, to ask "what changed?"
Then you take your answer and focus there. Not always true, but the odds are in your favor that whatever was changed is behind "the CHANGE" (for the worse).
In your case the list is spark plugs, spark plug wires, and distributor (cap?), and fuel filter.
Did you really change the distributor? Do you know if it's a good one? Have you tried putting the old one back? Forget the screw on the rotor (inside the dist)? Everything on straight? Forget to tighten the bolts on the dist? Knock a wire loose inside the dist while changing the cap/rotor? Still have the old wires in case the new ones are faulty?
Pretty much double and triple check everything you touched, and anything that stuff touches.. swap the old stuff back if you can just to eliminate items off your list and narrow down the possibilities.
What does a timing light tell you? Still dead on?
Good luck
Old Apr 1, 2011 | 08:54 PM
Hidenplanvew's Avatar
check plug wires at dist
Old Apr 3, 2011 | 08:18 PM
i changed the whole distributor to a new one. then i got msd wires and doubled checked the firing order and its correct. i made sure the plugs snap in all the way on the spark plugs. i reset the check engine light to. when i drive the car its ok then spontanuosly it starts acting up and misfires. i checked the engine light and it said cylinder 4 misfiring. ugh i swear this car is giving me a headache.. im just so lost with it.
CPreston
Feb 1, 2011 11:20 AM
ThisLittleSleepeR
Sep 24, 2005 04:33 PM
civicferio8381
Apr 6, 2005 06:20 AM
GreenEggs248
Aug 5, 2004 11:22 PM
sleepin91teg
Feb 27, 2004 11:05 PM
