95 Accord Knocking, Didnt Search
Old Apr 1, 2011 | 07:48 AM
4g4dcruisin's Avatar
Default 95 Accord Knocking, Didnt Search
Knocking sound coming from block, not tapping. I've never removed connecting rods or pistons so I was curious if i could remove the rods and the crankshaft by just removing the oil pan/pump.
What NORMALLY causes knocking anyway?
Old Apr 1, 2011 | 05:44 PM
phootbag's Avatar
Default Re: 95 Accord Knocking, Didnt Search
You need to remove the engine to remove the crankshaft.
Knocking is caused by excessive clearances, usually. But, on these vintage Accords, a "knocking" type noise is actually normal. If your noise is normal or not would depend entire on "your noise".
Old Apr 2, 2011 | 05:22 PM
92cb7sk8er's Avatar
i have never changed rods in an accord but in my 93 240sx we had to pritty much remove the motor but we did go though the bottem of the motor to get to them
Old Apr 2, 2011 | 06:36 PM
Accord Fanatic's Avatar
Knocking is not normal for this motor. Knocking may also be caused by a bent rod slapping the bottom of the cylinder You can drop the pan to see what is going on, but most repairs of this nature will require removal of the engine to repair.
brett pindell
JasonMD
Apr 22, 2018 10:19 PM
n2oiroc
13
Sep 8, 2010 09:21 AM
NyStreet's_4life
Jul 2, 2004 07:53 AM
VanHonda
Jun 21, 2003 02:25 PM
