Specs of DC sports header (mainly the primaries)
does anyone know the exact ID of the primaries and secondaries of the DC sports header? I'm trying to compare it to the specs that greddy sent me for theirs. thanks.
(PS - I know the collector on both is small)
Here are some measurements from a PO.com member (SK Honda 7). If you add the Greddy measurements to it... I'll add the Mugen.
-the measurements were taken from top all the way down to the cat-
--------------DC CC---------------------OEM 2001 5gen---------------
opening by the block:
------------46mm x 32mm -------------41mm x 32mm----------------
bottom opening of the upper portion (notice this portion is round):
---------------41mm--------------------------42mm-----------------
Opening on the down pipe(notice this portion is round):
---------------41mm---------------------------45mm-----------------
Opening at the end of down pipe by cat. (this is round as well):
---------------47mm---------------------------48mm-----------------
here is the email I got from greddy:
Thanks for your interest in GReddy Products
For the Prelude the 4 primaries are 42.7mm then collect to 45mm and then to 50.8mm
Please keep in touch with your favorite Authorized Greddy dealer for more updates. http://greddy.com/dealers/
[Modified by JDM LUDE, 7:13 AM 9/28/2002]
OK...here it is. I can only stand behind the Mugen figures because its sitting here next to me. The DC and OEM came from another PO member and s/b reliable. The Greddy figures should be verified by someone. All in all, I think its an interesting comparison.
Mugen-------------------------DC CC----------------------OEM 2001 5gen
46mm x 36mm---------------46mm x 32mm ------------41mm x 32mm
46mm----------------------------41mm---------------------42mm
46mm----------------------------41mm---------------------45mm
57mm----------------------------47mm---------------------48mm
{Edit: I took out the Greddy numbers in the above comparison...see my post below for why}
[Modified by Kool-Lude, 7:26 PM 9/30/2002]
speaking of Greddy headers...
anyone know if thier long awated header for bb6 is available yet? im assuming that the above specs are for thier 4thgen product eh...?
smsp??? who/what is that?
-b
[Modified by leptolude, 4:21 PM 9/30/2002]
-b
Tubing is measured by the OD not the ID.
The DC has 1-5/8" (41.3mm) primaries and 1-3/4" (44.5mm) secondaries. This is what DC uses for the majority of their Honda/Acura headers. I believe they use 16g material which is .065", so subtract .13 from the numbers above for the IDs.
That said...adding Greddy into this comparison was not accurate, so I'm taking it out of my posts.
JDM Lude: go with the specs SMSP posted as a comparison to Greddy.
[Modified by Kool-Lude, 7:28 PM 9/30/2002]
For a rough estimate, go by the OD. (I know... ID is what you want)
Take a piece of string and measure the perimeter of the tube.
Take that reading and apply it to the equation 2(pie)r = Perimeter to get your
radius. Double your radius and you got your diameter.
99BlackHatchSiR
Dec 27, 2005 11:00 PM
