cant get it started
Old Mar 31, 2011 | 10:22 PM
DrewUSARMY's Avatar
Default cant get it started
so ive got a 90 dx hatch with a freshly rebuilt LS non vtec with a fresh mpfi conversion. im getting fuel but no spark and i just replaced everyhting basically that makes spark.
any ideas.
Old Mar 31, 2011 | 11:05 PM
KINGVEM^^ED6's Avatar
Default Re: cant get it started
RECHECK ALL YOUR GROUNDS
Old Apr 1, 2011 | 09:10 AM
4g4dcruisin's Avatar
What distributor and ecu do you have?
Old Apr 1, 2011 | 07:33 PM
DrewUSARMY's Avatar
td 24 dizzy and a stock pr4
Old Apr 1, 2011 | 07:38 PM
Jockone's Avatar
Check to see if you have power to the igniter.
Old Apr 2, 2011 | 01:35 PM
DrewUSARMY's Avatar
im gonna change out my cap rotor and ignition module and recheck my wires. anyone got a ground wire diagram to make sure i got all my grounds right
Old Apr 2, 2011 | 02:50 PM
1990edsedan's Avatar
And don't forget to check the main relay..
Old Apr 2, 2011 | 03:13 PM
DrewUSARMY's Avatar
main relay is good my dumbass didnt checka ll the plugs and i had one no hooked up all the way and now the battery is dead
Old Apr 2, 2011 | 03:20 PM
put it on a charger overnight and it'll be ok..
Old Apr 3, 2011 | 11:41 AM
DrewUSARMY's Avatar
well she turns over faster now but still not firing. is there any other grounds i should check that could stop it from firing?
Old Apr 3, 2011 | 07:24 PM
DrewUSARMY's Avatar
im so lost
i just checked all my wiring again and its all good.
idk if wiring the resistor box directly to the injectors will work or not.
Old Apr 6, 2011 | 11:51 PM
10psiLsEf2's Avatar
look over the mpfi wiring.........had same problem before went over the diagram for dpfi to mpfi took my time and fired uppppp first crank. good luck
jdmacuraITR
Feb 4, 2013 05:37 PM
tuckandduck
Nov 11, 2008 09:39 PM
waterblast02
Mar 1, 2007 11:27 AM
wood 1
12
Sep 24, 2006 01:37 PM
yellow_jacket
Apr 17, 2004 11:17 PM
