jdm b20 swap 99 dc teg?
Old Mar 31, 2011 | 09:58 PM
92db2gs-r's Avatar
Default jdm b20 swap 99 dc teg?
i have a 99 ls which is the year where they started using crank angle sensors on the oil pump. jdm motors dont have crank angle sensors so instead of swaping my 200k mile ls oil pump with my 60k mile b20 oil pump couldnt i just use a 96-98 ecu or would i need a different harness too?
Old Mar 31, 2011 | 10:39 PM
mark@silbernage's Avatar
Default Re: jdm b20 swap 99 dc teg?
Search for CKF bypass or crank position sensor bypass (here, and/or google).
You can trick the system into using the signals from the distributor and avoid harness/ECU issues.
FYI
Old Mar 31, 2011 | 11:33 PM
92db2gs-r's Avatar
Thanks
miguel aguirre
Jun 4, 2016 11:23 PM
_gurusan_
Feb 24, 2015 02:27 PM
white_ej6
Jun 23, 2011 12:54 PM
GapxGuy
Nov 15, 2003 05:26 PM
eg6RR
Sep 14, 2003 06:09 PM
