vband sizes between housings
Old Mar 31, 2011 | 08:01 PM
boostedBLUfg2's Avatar
Default vband sizes between housings
out of curiosity, is there a difference between the vband downpipe outlets on a vband housing precisino turbo and the tial vband housings they sell for garrett turbos?
i have a kit made for the precision turbos with the vband housing, but i also plan on running a garrett turbo with the tial vband housing on it. will the two be interchangeable?
Old Mar 31, 2011 | 09:43 PM
TheShodan's Avatar
Moderator
Default Re: vband sizes between housings
No. they will not be interchangeable. 2.5" vband is precision. 3" v-band is TiAL housing.
Old Mar 31, 2011 | 10:03 PM
crap! so i'm going to have to hack up my dp to fit the tial housing?
Old Apr 1, 2011 | 07:39 AM
does anyone know of any adapters to make that work? i googled to no avail
Old Apr 1, 2011 | 07:40 AM
wantboost's Avatar
Who is Mr Robot?
its not hacking... simply cutting off a flange and welding a new one on. an adapter will be so long the downpipe wouldn't fit properly afterwards and it will probably cost more than doing it the right way to begin with... i.e having a new flange welded on
Old Apr 1, 2011 | 10:01 AM
true, guess i'll have to do that. sucks because the only place i would trust to do this is over an hour away. i don't want some sloppy welder putting on a new flange
Old Apr 13, 2011 | 08:46 PM
so i measured my precision housing earlier and it's 3", not 2.5". i googled it and a thread on evom said the pte inlet is slightly larger in OD, but it will fit. now i am wondering if they will in fact work.
Old Apr 14, 2011 | 08:34 AM
TheShodan's Avatar
Moderator
You mean the outlet. There are one or two threads here that have shown that they are in fact not interchangable, and only the ATP v-bands (other than Precision) are the ones to use. But you can check yourself. The GT-R T3/v-band and TiAL V-band use the exact same clamp, but again, is more than likely different from the precision one.
Now its time to take the plunge and find out.
Old Apr 14, 2011 | 09:10 AM
can you point me to those threads? i've googled but can only find the evom thread where a few people vouched that a tial housing can go on a setup for a precision setup, but not the other way around
Old Apr 14, 2011 | 10:24 AM
TheShodan's Avatar
Moderator
I wish I could. Its just based on being dilligent and using key word search on Google based on Honda-Tech as part of your search. I've seen them but its been sporadic over the last year. You'll find 'em. But give ATP a CALL, as they've done this switch a number of times.
SI_frankenstein
Jul 8, 2011 12:05 PM
96 GSR-T
Mar 22, 2010 04:18 PM
SD_Lurker
Dec 26, 2007 11:30 AM
boostedblack99
May 27, 2003 08:27 PM
Mr. Softee
Oct 7, 2002 01:46 PM
