Transmission & Drivetrain Gearboxes, Differentials, Clutches
Transmission Swapping/Converting?
Old Mar 31, 2011 | 03:20 PM
rinker_21's Avatar
Default Transmission Swapping/Converting?
I am currently looking at a 1998 Honda Civic HX. It has the D16Y15 Engine (V-TEC-E) with the automatic CVT transmission. I want to convert it to a five speed. What 5 speed transmissions will bolt up to it for a 5 speed conversion?
Thanks
Old Mar 31, 2011 | 03:29 PM
low91rex's Avatar
Default Re: Transmission Swapping/Converting?
Any d series hydro manual transmission. Best one to get would be an ex trans. Your going to need a bunch of stuff like shift linkage, 5sp pedal assembly, clutch master and slave cylinder w/ the lines, clutch, flywheel, axles tranny mount, and a 5sp ECU. The ecu is optional but you will throw a CEL all the time if you don't get the manual ecu.
Old Mar 31, 2011 | 03:35 PM
rinker_21's Avatar
Ok thank you....How far do the years for compatibility run?
Old Mar 31, 2011 | 05:17 PM
Gearspeed-Performance's Avatar
Go with 96-00 D-Series transmissions. They will be tagged S40.
Old Mar 31, 2011 | 05:30 PM
rinker_21's Avatar
Thanks
Old Mar 31, 2011 | 06:47 PM
94EG8's Avatar
Seagull Management
'92 - '00, if using a '92 - '95 transmission you'll want to grab a 5 speed upper transmission bracket for a '96 - '00 Civic though.
Btw, they're are some intricacies to do an auto to manual swap on an HX, the biggest being that it requires a custom upper transmission mount/bracket (which no other '96 - '00 Civic does, it has to do with the weird mount setup for the CVT tranny)
eg93LS
Aug 14, 2009 08:36 AM
-jacob-
Oct 31, 2008 03:57 PM
BeBe
Oct 7, 2004 07:44 PM
tshaw
Apr 11, 2004 06:07 PM
turismo128
Nov 14, 2002 01:13 PM
