Saggy doors! Replacement hinges?
Old Mar 31, 2011 | 10:23 AM
Canadian_EF's Avatar
Default Saggy doors! Replacement hinges?
I'm looking to replace my hinge bushings
Can't find a rebuild kit from Honda
Is there a hidden Honda secret?
It's been said newer Honda hinges work
But there is no solid information on this
Does anyone know of some quality replacements?
Thank you kindly
I await response
Old Mar 31, 2011 | 11:09 AM
1990edsedan's Avatar
Default Re: Saggy doors! Replacement hinges?
They are available aftermarket. Try Partsource/Crappy Tire first. Look for the door pin kits..
Old Mar 31, 2011 | 12:10 PM
KINGVEM^^ED6's Avatar
used from the junk yard...you sure yours are extra tight mine saged tightened them up and they were fine
Old Mar 31, 2011 | 12:21 PM
90_EX_Civic's Avatar
if you're going to the junkyard for hinges, make sure you get the ones from a 4door. the 4door doors are lighter. so less stress on the hinges.
Old Mar 31, 2011 | 05:40 PM
stackedhouse's Avatar
Someone posted on here all the hinges that were the same.. Like some of the newer civics used the same hinge so there prolly less beat up..
Old Mar 31, 2011 | 05:47 PM
Bertamus's Avatar
I have good sets for both passenger and drivers door. I doubt I'll be needing them.
Old Mar 31, 2011 | 11:01 PM
I might just be confused
on hondapartscheap.com it lists 2 part numbers per hinge.
67410-SM4-K01ZZ Hinge A
67410-SM4-K02ZZ Hinge A
and then there is the e-clip part number as well...
Each part is around $35, no e-clips are available at the moment..
So is it the pin we are missing then? I think I don't understand the problem. We tried drilling out the hinges to accept a bigger pin, but our drill press is off-center, so the bushing is loose. If I just put the hinge in a vice and used a good drill to drill it out instead, that would probably work better I guess. I'll try on Saturday and find out.
Are 4 door Civic hinges really the same as Hatchback ones!? Post a picture please, if it is true I'll have to venture out of town to a wrecker instead.
Old Apr 1, 2011 | 04:23 AM
Like I said, just get the door pin kit, comes with a new door pin and bushings.
Old Apr 1, 2011 | 07:47 AM
gnxpro24's Avatar
actually if you have a cr-x/civic hatch you want the same hinges from a two door. the doors or bigger so they handle more weight than the hinges on the 4 doors. they might all be the same who knows
look for part numbers, rockauto.com or somewhere, and compare btween cr-x and sedan, if theyre the same chances are the hinges were the same from the factory
Old Apr 1, 2011 | 11:20 AM
I have never seen said kit.
Do you have a link to a place I could order it from?
There isn't a shop around here that sells it.
Looking at part numbers, the 4 door rear hinges are completely different, but front hinges are the same, so thanks very much "90 Civic EX" and "gnxpro24" and "stackedhouse"
Makes sense the hinges would be good still since the doors are so much lighter.
Looking at part numbers for the 2000 Civic 2 dr, same number, coupe and hatchback. 4 door front hinges from 2000. I see what that guy was saying now that I'm looking at part numbers. (seems like the only different hinges are 4 door rear hinges, and 2 door 92-95)
90-97 Accord front hinges have the same part number, 2dr 4dr and Wagon also.
Thanks for the help you guys.
Old Apr 1, 2011 | 02:30 PM
Did you ask for it at Partsource/Crappy Tire? It's usually in the HELP section of the autoparts section. If they are **** poor in selection, then find a decent store - go to the jobbers who supply the mechanics..
Dorman does sell them. You can order them through any decent parts store.
http://www.dormanproducts.com/c-271-...aspx?pagenum=5
klerbman
Feb 2, 2019 07:45 AM
gomer124
Sep 20, 2015 01:19 PM
cvanderhoef
Jan 20, 2014 01:52 PM
aphex23
Sep 27, 2003 04:35 PM
Gen4-5Door
Sep 10, 2002 12:16 PM
