questions on 93 civic eg with b18 swap from 92 integra
Old Mar 31, 2011 | 09:06 AM
spaz69's Avatar
Default questions on 93 civic eg with b18 swap from 92 integra
First off, Im new here and looking forward to learning more about my civic. I recently got this civic from a guy. It Idles rough for the warm up, And when the car idles down upon warm up, it revs up and down, going from approx 1500 rpms to qbout 500-ish.. And I do know the car burns oil. I just checked my spark plugs and there was remnance of oil on em. They are deffinitely burning oil. Car doesnt really smoke bad, just a puff on certain cylinder(S). But my main concern is making it run correctly without the rev.. I have no thrown codes, But my first thought is iacv. When I drive it, It drives great, Minus the stumble in the firing cause of the oily plugs...although the new plugs helped in the rough idleing a little bit...I am fixing to pull the cyl head off and change the head gasket. Anyone know what the reving could be from and any insight on any other prob I should look for on the oil leak/burn problem? Thanx for all your help.. Daniel
Old Mar 31, 2011 | 11:36 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: questions on 93 civic eg with b18 swap from 92 integra
clean your IACV for sure
and delete the FICV with a homemaid plate
replace the gaskets under the valve cover around the spark plug tubes.
do a compression test.
clean the node thingys on the bottom of the dizzy cap.
good luck.
ronjoht has alot of info in his sig
Old Mar 31, 2011 | 12:05 PM
spaz69's Avatar
good luck.
Ok, Imma a dummy, Whats a FICV? Wheres it located? I just replaced the valve cover and spark plug tube gaskets this morning. And the dizzy cap, Is that reference to my distributor? Thanks fer your help..
Old Mar 31, 2011 | 02:37 PM
I'm not Rick!
fast idle control valve.
under the throttlbody.
delete it with a homemaid plate and rtv glue
and then bypass the hose from the block to the head/manifold
ya dizzy aka distributer. take it off and clean the corrosion on the diods.
farely cheap you can always get a new cap for $12 for autozone and a new rotor(which is inside the dizzy under the cap) for like $10
Old Mar 31, 2011 | 05:18 PM
spaz69's Avatar
Thanx. Imma just update all my parts as i go also. The fast idle air control valve , is that for the fast idle for warm up? And if so what will happen? Will the car just run at normal idle instead? Man i feel like a ratard. Lol. Thanx for your help and patience
VeryUnoriginal
Mar 20, 2014 08:15 PM
mscar111
Mar 26, 2012 11:51 AM
MyHondaIsSlow
Mar 20, 2011 12:38 AM
anthony27302
Jul 2, 2010 08:30 PM
ITLNstallion818
Nov 5, 2008 05:32 PM
