changed headgasket, now the tranny shifts higher rpms
I requested a short story for a title.
heys guys i recently just did the the headgasket in my eg, got everything taken apart and put back together but now im noticing the rpms climbing higher than the used to before it shifts gears. I took the intake manifold off when i did the gasket so im thinkin maybe the overdrive cable that hooks to the throttle body might have gotten un adjusted.
my question is how do you know where to set it to so itsd back to factory? is there like a diagram or something to look at instead of just moving it and going for a drive? please HALP!!
thanks guys
thanks guys
Are you talking about your throttle cable?
Sounds more to me like a possible vacuum problem. That is if it's that much higher Rpms.
Ya im gallon about the tv cable..how do u know which way to adjust it to make it better..and the its not a huge difference from before but u can deff tell a difference from before
1baddturbosi
14
Aug 10, 2007 06:37 PM
Rice4me
Jul 4, 2001 05:24 AM
