94 Civic - popping noise when turning left
i got a 94 civic 4 door and when i cut my wheel almost all the way left something pop but it doesnt do it when i cut it right, it has new tie rods also. any help would be appreciated.
Check your ball joints along with the axles. Ball joints should have no more than a nickle's thickness worth of play in them. The proper way to check them is to lift the car slightly off the ground, put a pry bar between the ground and the tire, and pull up on the tire. If it is your ball joints, fix them before you drive the car again, if a ball joint goes out, you will crash. How do I know? Seen it happen in person.
Check your ball joints. I have a 92 civic hatch and mine was doing the same exact thing but it was when I turned the wheel to the right. I changed the ball joint and it fixed the poping problem its worth a shot.
picthis1
Feb 1, 2012 08:32 PM
barone
Sep 5, 2011 07:41 PM
CleanHatch
10
Oct 23, 2005 09:52 PM
