FS/FT, FULLY Built D16z6, Eagle rods, Bisimoto Cam, 7:5:1 Compression BUILT FOR TURBO
Finally made up my mind and want to trade my fully built D series. I need a reliable car and don't have enough money to finish my project also. Im looking to trade for a full swap.
I do have paperwork from my machinist who built it.
Bump if you view please.
Motor is very healthy and using Mobil 1 Fully synthethic 10w30. Motor has 5800 Miles in break in. Oil changed every 3000 miles
Head- BRAND NEW OEM HONDA GASKETS
Ported and polished
Supertech Valve Springs and Retainers
Gasket matched
5 angle valve job
Bisimoto Stage 3 Camshaft N/a
Bisimoto Cam gear
Skunk 2 Pro Series intake manifold
B16 Throttle body
Brand new Arp headstuds
Aem Fuel pressure regulator
Blox fuel pressure gauge
Bottom End-
Ycp Vitara Pistons, 7:5:1 Low compression
Eagle H Beam Rods
Golden eagle block guard
Ported z6 Pump, idle is 25 psi, (good oil pressure )
Tapped oil pan
Innovative 75a Motor mounts, very stiff
ACL race bearings
Trans-
S40 ex trans
5800Miles on Xtd stage 3 clutch
7lbs flywheel
5 Speed Manual
Short shifter
Pics of the motor when i got it back from bill
Ported and polished
Gasket matched
5 angle valve job
Bisimoto Cam gear
B16 Throttle body
Bottom End-
Eagle H Beam Rods
Tapped oil pan
ACL race bearings
Trans-
S40 ex trans
7lbs flywheel
5 Speed Manual
Short shifter
Man motor looks really good man this is the same route that I'm doing for mine I'm just trying to figure my prices out but wont to turbo it but im not. I don't a awd ef with a fully built z6. I'm getting all the body work dont n repainting it as well. I really wish I can take this beast off your hands. Nice work man. Glws
Bump.
Bump for a good d build. Whats up with the N/A bisi cams in a turbo build??? Just trying to help... GLWS
xkrazyxjbrkerx75
Dec 2, 2011 10:38 PM
xkrazyxjbrkerx75
Oct 24, 2011 11:56 AM
xkrazyxjbrkerx75
Oct 9, 2011 07:51 AM
xkrazyxjbrkerx75
Sep 14, 2011 05:35 PM
xkrazyxjbrkerx75
Feb 2, 2011 10:58 AM
