D16Y8 rebuild.. break-in question
Old Mar 30, 2011 | 05:07 PM
crk112's Avatar
Icon2 D16Y8 rebuild.. break-in question
Ok.. in the middle of a D16Y8 overhaul (1998 Civic EX.. 243,500mi). I'm changing piston rings and rod bearings (and yes both can be done with the engine in the car.. also did a D15B2 the same way about 10 years ago )
What's the best way to break in the rings? I was under the impression that idling should be kept to a minimum.. and that the engine should be put under a load as soon as possible and basically to "drive it like I stole it" for the first 500mi.
But then I found a CAUTION in the Honda Service Manual (it's a Honda book.. not Chiltons or Haynes) that says if you replace the bearings the engine needs to idle up to operating temp.. then for another 15 minutes after that. I understand D16Y8s are good at spinning bearings.. obviously I want to avoid that, but I also want to make sure the rings get a good seat.
What has been your experience?
Thanks all,
Curtis
Old Mar 30, 2011 | 08:40 PM
sde780's Avatar
Default Re: D16Y8 rebuild.. break-in question
I rebuilt my d15b2 almost 3 years ago, I broke in the rings by letting it idle for ~10 min just to check for leaks/problems, then I went almost to redline then let it deccel in gear, then slowly go back up and let it deccel in gear. I think the main thing is to let it deccel in gear
Old Apr 2, 2011 | 12:03 PM
crk112's Avatar
Thanks for the advice.. that should be a piece of cake for me lol since I decel in gear as much as I can anyway. :-)
I take it you had no problems after that?
crk112
32
Sep 23, 2023 04:21 AM
Ryan Lwin
Oct 22, 2014 11:16 AM
Cerberus10411
Sep 11, 2014 11:00 AM
JDMHondaEJ8
Oct 3, 2010 01:29 PM
trav39562
Apr 1, 2009 11:59 AM
