does the s300 bypass anything over the p13 default??
Old Mar 30, 2011 | 04:49 PM
1SLWEJ1's Avatar
Default does the s300 bypass anything over the p13 default??
Im trying to fix a car i picked up, 99 hatch with a h22 swapped in it. the car has high impedance injectors, obd1 and will only run on my other cars s300. it will not run on a p13 that came with it. my car has a h22 as well with dsm 450cc and a resistor box. the p13 and my s300 both run my car just fine. the only thing thats different is the injectors and resistor box. but from what i know low impedance need a resistor box and high impedance do not. so is there something in the s300 that is different or bypassing something to make the civic run vs the stock p13?
Also I have a pheriable.net socketed n chipped po6 that ran my last H civic that will not run this car??
Old Mar 31, 2011 | 08:53 AM
1SLWEJ1's Avatar
Default Re: does the s300 bypass anything over the p13 default??
Old Mar 31, 2011 | 08:54 AM
grumblemarc's Avatar
The Grumpiest
Why don't you just compare the 2 maps?
Old Mar 31, 2011 | 02:41 PM
1SLWEJ1's Avatar
They have the same maps hooked up lap top set it to prelude has map n 310cc injectors both ecus ran my one car and only hondata ran my ek
Old Mar 31, 2011 | 07:20 PM
1SLWEJ1's Avatar
Noone knows?
Old Mar 31, 2011 | 07:23 PM
94EG8's Avatar
Seagull Management
Hondata setup probably doesn't look for an EGR valve, but that shouldn't make any difference in starting the car.
Old Mar 31, 2011 | 08:23 PM
1SLWEJ1's Avatar
No. I just don't get why hondata s300 will run my car and a chipped po6 and stock p13 won't??
Old Mar 31, 2011 | 09:13 PM
farfrumugen's Avatar
try the tuning forum or take it to a tuner and have them look at it. i have no clue when it comes to actual tuning so i have no real info to add other that their MUST be a difference in the ecus as far as i could tell. contact some hondata experts and maybe they can tell you.
adam
Old Mar 31, 2011 | 09:45 PM
1SLWEJ1's Avatar
.. Thanks for your input anyone else?? Need help that's why I'm here on H-T lol
Old Mar 31, 2011 | 10:15 PM
mooze's Avatar
what ecu is the hondata in?
Old Apr 1, 2011 | 12:47 PM
1SLWEJ1's Avatar
Non vtec po6
Old Apr 2, 2011 | 10:35 AM
1SLWEJ1's Avatar
NOoNe knows this?
Old Apr 2, 2011 | 10:39 AM
The Grumpiest
You really need to get in touch with a tuner. At the very least contact Hondata.
Old Apr 2, 2011 | 11:50 AM
1SLWEJ1's Avatar
That's it? Noone knows anything about this ...
Old Apr 2, 2011 | 12:00 PM
The Grumpiest
I think the lack of responses to your questions are an obvious indicator.
kevino002
May 4, 2005 01:47 PM
wappid
Apr 2, 2005 08:53 PM
slixxracing
Mar 23, 2004 05:22 PM
platinum00
Jan 22, 2004 10:42 AM
Sprockets
Dec 21, 2002 12:56 PM
