Need some lathe work done....
Old Mar 30, 2011 | 04:30 PM
Blown90hatcH's Avatar
Default Need some lathe work done....
I realize this is small time for some of you machinists.....but I need some one to turn some hex stock on a lathe and tap/cut threads. I threw together some fast drawings of what I am needing. Prefer stainless but if I have to go MS, I will take it. Need Qty. 4 of the small ones and Qty. 2 of the longer ones. Dims are in mm with the exception to the one hole that is 10-32 thread. Both the short and longer ones are M6x1.0 cut threads on the one end. This is for some fuel rail standoffs for those inquiring minds. I can do better drawings, igs/dxf/dwg, etc. if you need them.
Let me know ASAP price and lead time. Thanks!!!!
PDF of the drawings
http://photos.imageevent.com/jasonk/...il%20bolts.pdf
Old Mar 30, 2011 | 06:02 PM
k24em2's Avatar
Default Re: Need some lathe work done....
What are your tolerances on the hex?
Old Mar 30, 2011 | 07:32 PM
As far as? I would prefer the hex as spec'd in the drawing....typical mill draw of 3/8", but I got your PM about the 7/16". I can make that work if I have to.
Old Mar 31, 2011 | 10:45 AM
k24em2's Avatar
I don't have any hex in stock, I'd have to order some
Old Mar 31, 2011 | 11:12 AM
Ok man. Quote me and send me a PM with the details.
Thanks.
Old Mar 31, 2011 | 06:58 PM
mrbsponge's Avatar
Jason doesnt play when he needs something
Old Mar 31, 2011 | 07:14 PM
poorboy44's Avatar
exactly lol
Old Apr 1, 2011 | 05:57 AM
Haha. Don't make me go buy a lathe dang it.
Old Apr 1, 2011 | 06:25 AM
denske's Avatar
cant you just remove the injector cap? and put the rail right on the injector?
Old Apr 1, 2011 | 02:03 PM
legendboy's Avatar
still looking for these parts?
Old Apr 1, 2011 | 06:31 PM
Yeah man. Still need them.
Old Apr 2, 2011 | 07:26 AM
k24em2's Avatar
I can probably turn them out of stainless round bar and machine some wrench flats on it...I have stainless bar in stock
Old Apr 2, 2011 | 08:20 AM
Yeah man, that will work too. Just want this done....time and price. PM me if you are serious about making them.
Old Apr 2, 2011 | 10:06 AM
Linh.'s Avatar
Pretty simple job. You can post on practicalmachinist.com if noone here gets it done.
Old Apr 2, 2011 | 06:02 PM
Thanks man. Very simple job indeed.
Old Apr 3, 2011 | 06:41 AM
tony1's Avatar
I have shorter tops for the injectors if you need them Jason, they are 12mm shorter.
Old Apr 4, 2011 | 01:11 PM
mikesrex's Avatar
find some all thread and weld nuts onto it lol
Old Apr 6, 2011 | 11:10 AM
legendboy's Avatar
K i will try to remember to see what I have for 3/8" hex stock when I get home
I know for sure i have it in brass and C12L14, thats probably it tho.
I could do em in 12L14 and have them plated if you wanted
97grnrs
Aug 18, 2008 06:25 PM
vaporboy12
May 6, 2006 08:42 AM
Pandahatch
Jan 13, 2006 03:17 PM
Acura_I-RS
Sep 9, 2003 07:48 AM
Asahi
Sep 4, 2003 04:11 PM
