D.I.Y ITR Pedals Instal
Today I'm going to walk you through how to do a pedal installation. I'm going to be installing ITR pedals onto my DC5.
Tools needed:
Drill/drill bits
Rivet gun and rivets
Center punch
Towel
Block of wood
Lets begin!
First layout your pedal to just make sure you got them and glimpse of the sexyness to follow
Lets start with the dead rest... very simply pull with some strength as the dead rest is held in with two tabs
(back of pedal)
And simply press the new pedal in place! That easy :thumb:
Ok now lets get your car ready. Place the towel under your pedals. This is to catch all the metal shavings! The wood is needed to hold support to the pedals while drilling and to catch the bit when the drill goes through.
Alright now lets start with the clutch and gas. Simply pull the stock rubber covers off to start
Now test fit your new pedals. When ready take your center punch and punch holes in the pedals where needed
I used two drill bits. Small one to start then the bigger one afterwards. Makes things easier.
Now after doing all three holes place your pedal back on and test fit the rivets.
If they all align make sure the pedal is fully on and grab your rivet gun!
Now you have a fully secured pedal!
Do the same for the other two pedals and bam! JDM bling
Tools needed:
Drill/drill bits
Center punch
Towel
Block of wood
Lets begin!
(back of pedal)
ITRFetish2000
Apr 22, 2004 04:02 PM
A.S.I.M.O
Mar 25, 2004 09:18 AM
