D.I.Y Honda Key Conversion
Old Mar 30, 2011 | 02:00 PM
Type-Spaz's Avatar
DC5/EP3 MOD :)
Default D.I.Y Honda Key Conversion
So I finally finished the last of my Honda conversion. Woohoo. I bought a Honda Accord key and a blank Acura key I had cut and then cut it to fit inside the Accord Key fob...
So here is the new key. It's from a Honda Accord and it's been modified to use my acura key
So first I took it over to ace hardware and had my key cut
Then I took a razor blade and cut open the old key to remove the immobilizer
there it is in the center
now I open the new key fob and pull out the factory immobilizer for the accord
put the RSX one in the accord key
and BAM! Now I have my new key and a blank spare!
now time to program the new fob
Turn the ignition switch ON (II).
Within 1 to 4 sec. , push the transmitter lock or unlock button with the transmitter aimed at the receiver under the audio unit.
Within 1 to 4 sec. , turn the ignition switch OFF.
Within 1 to 4 sec. , turn the ignition switch ON (II).
Within 4 sec. , turn the ignition switch ON (II).
Confirm you can hear the sound of the door lock actuators. Within 1 to 4 sec., push the transmitter lock or unlock button again.
Within 10 sec. , aim the remaining transmitters (up to two additional ones) whose codes you want to store at the receiver, and press the transmitter lock or unlock buttons. Confirm that you can hear the sound of the door lock actuators after each transmitter code is stored.
Turn the ignition switch OFF, and pull out the key.
Confirm proper operation of the transmitters.
Then also bought this.
bad pictures but you get the idea... the back half of the key fob I ordered finally came in today woohoo! Straight from Japan
ENJOY!
Old Mar 30, 2011 | 04:42 PM
NEO_FOLLOWER2's Avatar
Default Re: D.I.Y Honda Key Conversion
did you get the hatch release button to work.
that would be a veryy nice addition =D
Old Mar 30, 2011 | 04:49 PM
Type-Spaz's Avatar
DC5/EP3 MOD :)
No because the RSX doesn't have a remote button pop it has old school cable pull hatch.
They make a key without the trunk but it was more money
Old Apr 13, 2011 | 08:59 AM
BigZ88's Avatar
This should technically work with an ep3 correct? Since I'm buying extra keys anyways...
Old Apr 14, 2011 | 07:20 AM
mustclime's Avatar
not for my 03, the blank is completely different....
Old Apr 14, 2011 | 08:06 AM
BigZ88's Avatar
crap on a cracker...
Old Apr 14, 2011 | 08:39 PM
SJ_PP10's Avatar
damn thats cool. how much did this all cost you about?
Old Apr 15, 2011 | 07:32 AM
Type-Spaz's Avatar
DC5/EP3 MOD :)
its not as costly as time consuming
Old Apr 15, 2011 | 07:57 AM
DaveSi677's Avatar
to bad it won't work on the EP!
Good write up btw
Old Apr 15, 2011 | 10:27 AM
Samuraij's Avatar
Superfly
sorry for sounding stupid for asking this but what makes an ep's key so different that this wont' work for it?
Old Apr 18, 2011 | 11:20 AM
mustclime's Avatar
ep key has no groves, Its designed for a different kind of lock.
Old Jun 29, 2011 | 06:07 PM
optiquest242's Avatar
Great write-up!
A couple questions,
Did you have to buy another acura key or could you have used the one that you opened to remove the immobilizer? Or did you just buy another one to have a backup key that worked? Also what kind of modifications did you have to make to the key to get it to fit in the fob? And did you just epoxy it in there or what?
I've been wanting to do something like this with my CRX by getting a key fob like you did and the keyless module but I always figured if I mod'd the keyfob the new key wouldn't fit in the fob well or it would be flimsy. Any more info you have would be great.
Old Jun 29, 2011 | 07:53 PM
Type-Spaz's Avatar
DC5/EP3 MOD :)
Originally Posted by optiquest242
Great write-up!
A couple questions,
Good questions I should have answered:
I bought a spare key and had it cut from the hardware store. I cut it apart with a dremel but I apparently forgot to take photos... Just match up to the old key you pull out. And yes I used JB Weld to glue the key in place.
Old Mar 13, 2016 | 11:26 AM
Alex Brown's Avatar
I want to do this with my 99 Accord but I cannot find a key like this one with that blade that you have. Where did you get that? And how much was it?
Old Nov 1, 2018 | 07:37 PM
turbo sol's Avatar
do you have a part number for the accord key? .or know what years i should be looking for?
Old Nov 2, 2018 | 11:17 AM
02ep3SiR's Avatar
Hey - New to the forum and I've been researching keyfob ideas. The '02 EP3 key does look like this. It's the '03 + that have those wide, laser cut keys. Might this work for an '02? I actually wanted to change the ignition to an '03+ just for the key, but this may be an even cooler, more practical idea.
I'll post a side by side tonight I forgot my phone at home today lol.
Old Nov 2, 2018 | 11:40 AM
tommycrx's Avatar
The key should work, as long as whomever cuts the key does it properly.
I'd look into a TL-S blank, - though. Looks cooler and is a switchblade. I've had mine over two years now and it's still folding up fine.
And yes, the programming is as annoying as the directions make it look.
Old Nov 2, 2018 | 12:20 PM
02ep3SiR's Avatar
Do you guys know of any practical way to switch over to an '03 + key at the same time? I know I would need the ignition, door/trunk locks, immobilizer.. anything else I'm missing? I spoke to one person on Kijiji who was parting out an '04 ep3 he crashed, and now has an '02. He switched all the keys / locks over but said he lost his 'Anti-theft'.. I wasn't sure what that meant and I couldn't get a better description but that would be quite important to me to retain the immobilizer & 'Anti-theft' if they are the same thing even..
cerg0417
Jun 2, 2017 07:31 AM
usefz89
Oct 6, 2013 11:55 PM
Type-Spaz
26
Oct 1, 2009 01:33 PM
