S20 TRANS OIL CHANGE
Old Mar 30, 2011 | 01:00 PM
arkomandos's Avatar
Default S20 TRANS OIL CHANGE
HELLO EVERYBODY,,,I am working on the right drive axle,,,because it was leaking from the seal and I lost alot of fluid,,,,I already drained the remains and have two question's ,,,what fluid would be the best,,,how about Royal Purple Max Gear 75W 90 ,,,and also how much oil do I put in?? do I go all the way till it pours out of the fill hole???
Old Mar 30, 2011 | 01:12 PM
hyperblu's Avatar
Default Re: S20 TRANS OIL CHANGE
pennzoil synchromesh 2.2-2.4 qts.
Old Mar 30, 2011 | 01:16 PM
94EG8's Avatar
Seagull Management
10W30. Do not under any circumstances run gear oil. And yes, pour it in until it runs out the fill hole
Old Mar 30, 2011 | 05:44 PM
arkomandos's Avatar
would the amsoil synthetic synchromesh 5w-30 also work or would it be loo lean,,,,I can't find the grade for the pennzoil synchromesh but it looks like 10w-30
Old Mar 30, 2011 | 06:10 PM
94EG8's Avatar
Seagull Management
Not synchromesh, just plain old cheap 10W30 motor oil.
Old Mar 31, 2011 | 05:17 AM
300whpej's Avatar
honda mtf is now just as good if not better than synchromesh 2.25 qts is all you need
Old Mar 31, 2011 | 05:18 AM
94EG8's Avatar
Seagull Management
It's too thin for older D-series trannys though, '96+ S40 trannys you should run MTF in (they actually shift like crap with 10W30) but the older S20 trannys should have 10W30 in them.
jdm702
Apr 15, 2010 04:50 AM
Mashka
Honda S2000
Sep 3, 2007 01:50 PM
Gsir8
Jan 22, 2007 07:13 PM
THEFXR
May 18, 2006 01:32 AM
MtnCRX
Apr 24, 2005 06:36 PM
