Swapped B18C1 in '90 Integra; 3rd Gear going to 95 mph?
Old Mar 30, 2011 | 10:46 AM
tactzer0's Avatar
Default Swapped B18C1 in '90 Integra; 3rd Gear going to 95 mph?
My speedometer has been pretty much shaking since I got the car 8 months ago and I just replaced the cable recently which fixed the shaking problem. However, is it normal for my gears to be so far ahead? First goes past 40 mph; second goes to 65 mph; 3rd goes to 95 mph, 4th goes past 125 mph.
Should I be worried about this or is that just how long the ratios are?
Old Mar 30, 2011 | 10:49 AM
vrrodri's Avatar
Default Re: Swapped B18C1 in '90 Integra; 3rd Gear going to 95 mph?
WHat does your butt dyno tell you? You really think you are doing 95 mph on third?
Old Mar 30, 2011 | 11:01 AM
tactzer0's Avatar
Umm... I mean... lol I wouldn't doubt it >.>
Should I post a video?
Old Mar 30, 2011 | 11:05 AM
almotor18's Avatar
loool wat trans are u using?
Old Mar 30, 2011 | 11:11 AM
tactzer0's Avatar
I'm guessing the trans out of the 2000 GSR it was swapped from. Honestly, I'm not 100% sure and at the time of purchase I wasn't as knowledgeable so I over looked that potential question. Let's create a scenario for both. Maybe it's still the original tranny from the DA and it's 20 years old >.>
Old Mar 30, 2011 | 12:15 PM
Zombie1890's Avatar
Got a smart phone? If ya do download a GPS speedometer app or if ya got a GPS usually they will tell you how fast you are going. If you have non of the above have a buddy drive beside you on the highway and compare speeds or something. If you are doing 95 in third then its just the gearing of your tranny
Old Mar 30, 2011 | 01:07 PM
komat's Avatar
its normal for 3rd gear to be 90+
Old Mar 30, 2011 | 01:42 PM
tactzer0's Avatar
Alright, I posted a quick video.
http://www.youtube.com/watch?v=nw9_CNE8ISs
Old Mar 30, 2011 | 02:53 PM
tactzer0's Avatar
Really? I mean, I can understand 90 but 95 seems a little excessive. So all you guys with GSRs are able to get around 95 mph in 3rd?
Old Mar 30, 2011 | 03:25 PM
KillerDA's Avatar
Nah there is something wrong with the speedo there is no way that motoer should do 140 in 4th gear unless you tached out. i would check the cluster and the cable that runs to the tranny
Old Mar 30, 2011 | 03:33 PM
tactzer0's Avatar
I'm in 5th by 140, 4th goes to around 125. The cable was just replaced.
Old Mar 30, 2011 | 03:43 PM
1998GsRIntegra's Avatar
Hmmm seems right actually. If its a b18c1 trans, then 95 in 3rd gear is about right. Ive gone to 120 in 4th at 7700rpm, so yea. I really doesnt seem off. Get your camera buddy to ride beside you at 60mph on his cluster and see what yours says. Simplest thing to do.
Old Mar 30, 2011 | 05:24 PM
dntnedvtec's Avatar
Tire size??
Old Mar 30, 2011 | 05:49 PM
Originally Posted by dntnedvtec
Tire size??
Very good point
Old Mar 30, 2011 | 06:16 PM
TunerN00b's Avatar
Most cars are in the 60 to 70 mph range for redlining 2nd gear, and a GSR hardly has "long" gears...
Those speeds for redline are close enough to correct for a GSR. (68 in 2nd, not 65.)
The speedometer reading is taken from the diff, and is only accurate if the tire size is correct (195/55-15, which is 23.3" in diameter).
Old Mar 30, 2011 | 06:20 PM
tactzer0's Avatar
Tire size??
195/55R-15
Old Mar 30, 2011 | 07:20 PM
vtecdc4's Avatar
seems normal to me?
lol is it a stock motor?
Old Mar 30, 2011 | 08:10 PM
tactzer0's Avatar
Originally Posted by vtecdc4
seems normal to me?
Yeah it's stock. I guess everything is ok then
Thanks for confirming.
Old Mar 30, 2011 | 09:04 PM
turboskratch's Avatar
Seems right to me. Easiest way for me to tell is if you're going 80mph in 5th and your RPM is at 4k, then it's a GS-R trans.
Castl3Magic
Feb 27, 2014 02:49 PM
Jamie Martin
Dec 27, 2012 05:47 AM
crackegg
Sep 20, 2005 03:43 PM
turboME
Jun 24, 2005 02:33 PM
