Opinion, DIY EK camber kit
adding shims to the mounting bolts would do nothing. adding or removing camber would require you to move the arm in or out (in this case the ball joint).
if you could somehow get an eccentric bolt to work i can see, but you'd never really get both bolts to line up correctly and throw off your caster.
