bent crank??
Old Mar 30, 2011 | 06:34 AM
chope045's Avatar
Default bent crank??
i put my motor back together and i noticed my crank pulley was wobbling i switched it out and it did the same thing is my crank bent or worped
Old Mar 30, 2011 | 06:37 AM
hyperblu's Avatar
Default Re: bent crank??
how much wabble? There will be SOME wabble, but not much. Unless you get your crank balanced...
Old Mar 30, 2011 | 06:42 AM
boostedb20ek's Avatar
I doubt your crank is bent, it would take alot to bend crank. What was the reason for pulling the motor? Was it fully disassembled?
Old Mar 30, 2011 | 11:16 AM
chope045's Avatar
i figured it out when i put the timing belt pulley on it didnt sit flush causing the harmonic ballencer not to sit flush
bks84
Engine Machining & Assembly
Jun 29, 2015 01:51 PM
RAB
Oct 13, 2004 05:45 PM
flat-blk-HB
Jan 13, 2004 07:26 PM
Turbolude
Sep 12, 2001 05:53 PM
