CB7 Accord...Extended stud install question
Old Mar 30, 2011 | 05:14 AM
noridetoolow's Avatar
Default CB7 Accord...Extended stud install question
Can you install extended studs WITHOUT pulling the hubs? Front and back? I have a 92 EX so disc brakes all around. I need to replace most all the studs anyway so figure if I can do so without pulling and replacing the bearings I would like to do so. Asked the guys at CB7tuner and got what sounded like a "yes you can install without pulling the hubs" answer but it still wasnt real clear. Need to know if someone has done this. I know its not possible on an Integra or Civic....the CB7 is ALMOST identical but im hoping its different enough to make this possible! Thanks!
Old Jun 9, 2011 | 05:59 PM
project_cb7's Avatar
Default Re: CB7 Accord...Extended stud install question
no such luck.ive installed arp extended studs all around on my 91 cb7(rear drums).the fronts i had too pull hubs.sorry for the bad news bro.
Old Jun 10, 2011 | 04:46 AM
Balwin's Avatar
Might as well go ROH or 5 lug.
Old Jun 11, 2011 | 06:16 AM
poorman212's Avatar
I've relaced studs without pulling the hub....pull the caliper....I know a stock length stud will go in, not sure how much longer yours are.
or you can go with Balwin's suggestion.....
Old Jun 12, 2011 | 06:23 PM
Balwin's Avatar
I have installed studs without pressing the bearings out but there is no way that will fly with extended studs. The angle is too big and it just wont work unless you notch the knuckle or something.
Old Jun 12, 2011 | 06:40 PM
Yeah I went ahead and installed Oem studs and they were easy all around. I need to install new rotor soon anyway so I'm just going to hold off till I do that and take care of it and extended studs all at once. Thanks for the replies
bmwe362006
Feb 23, 2009 06:21 PM
Quickridez_3
Sep 30, 2008 04:08 PM
crv-techu
Jun 10, 2008 01:51 AM
bigBOI_92DA9
Aug 19, 2005 08:33 AM
skankz_em1
Jan 31, 2004 08:01 AM
