how hot is too hot- GSR turbo for the track
Old Mar 29, 2011 | 07:59 PM
akcapr's Avatar
Icon2 how hot is too hot- GSR turbo for the track
I havea trubo stock GSR pushing 300 to the wheels, 11 psi, etc. Im looking to hit the track, but worried my car cant handle the relatively long period of boosting and generally driving hard. i have a dual row aluminum radiator, new thermostat. At normal driving my water temp is about 180 farenheit ( i have a aftermarket water temp guage). I mashed one time on this windy road, about 4 miles, boosting and just driving hard in general, and the water temp got up to 220 farenheit. and man that seemed pretty hot i got worried that im getting close to overheating...
so my question is, how hot is it ok to let me water temp get? Particularly for if i go to a track. just want to know when i should start slowing down and getting worried.
thanks!
Old Mar 29, 2011 | 09:26 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: how hot is too hot- GSR turbo for the track
too hot...
try a lower temp fan switch and a lower temp thermostat.
try an aftermarket higher cfm fan as well
boosted_b16a2's Avatar
180-195 perfect. 220 let it cool down asap. 250 is BOOM.
Old Mar 29, 2011 | 09:35 PM
akcapr's Avatar
i have my fan wired externally, so its always on. its a half-size radiator, wish i could fit a full sized one
Old Mar 29, 2011 | 09:38 PM
racebum's Avatar
220 is absolutely nothing to worry about. going past 240 is when you have to back off. actually, if your water and oil temps keep climbing the car needs cooling addressed period. also by dual core do you mean a full size dual core? we had a pretty length discussion on this in the road racing forum and the general consensus is you don't go road race on a half rad.
Old Mar 29, 2011 | 09:46 PM
akcapr's Avatar
its a half size dual core... is there anyway to maybe mount two dual core radiators? that would be interesting.. ill check it out in the road race forum thanks. what do other turbo road racers do about the radiator size?
Old Mar 29, 2011 | 10:15 PM
komat's Avatar
you get a full size dual core not two half size dual core....
Old Mar 29, 2011 | 10:27 PM
akcapr's Avatar
i know a full dual core would be best, but i dont think i could fit it in with my manifold setup. heres a video of the driving i was doing when my water temp hit 220 towards the end. i guess considering it was relatively long drive that wasnt too bad- i think a triple core radiator should help me out nicely.
http://www.youtube.com/watch?v=FFrDxD4-kls
please dont give me any flak in regards to the video, just trying to make it more clear
and yes i know the tach isnt working
Old Mar 29, 2011 | 10:58 PM
AllShowNoGo727's Avatar
get the ebay triple core im using it with no over heating problems.
Old Mar 29, 2011 | 10:59 PM
akcapr's Avatar
how long/whats the longest youve pushed your car without taking a break, and not overheating?
Old Mar 29, 2011 | 11:03 PM
boostedBLUfg2's Avatar
your windshields cracked bro
Old Mar 29, 2011 | 11:06 PM
akcapr's Avatar
oh thanks... didnt notice...
Old Mar 29, 2011 | 11:29 PM
Coupe93's Avatar
LOL
Old Mar 30, 2011 | 04:17 AM
kyden's Avatar
you need airflow to the radiator. if you drive with the bumper off you'll notice lower temps.
Old Mar 30, 2011 | 06:33 AM
DelSolMarine's Avatar
spal puller fan w/ shroud and your problems are solved... not an opinion... its proven
Old Mar 30, 2011 | 08:02 AM
92redhatch's Avatar
You need a nice fan and your problems will be solved. Get a spal fan with a shroud and don't look back. You don't want your temps past 200imo I had issues with heating and spent a lot of money coating things and it helped but not as much as I hoped. Btw E85 helps a lot also.
Old Mar 30, 2011 | 08:16 AM
97CWITR's Avatar
I don't get why everyone keeps talking about the fan?
Isn't a fan just there to move air through the rad while the car isn't moving?
He's moving quickly, so shouldn't there be sufficient air flow over the rad?
Old Mar 30, 2011 | 08:30 AM
chialpha2006's Avatar
driving fast in the wrong lane headed towards blind corners is a great idea... please get to the track before you kill yourself or somebody else and stop driving on the street like a jackass... just my .02
Old Mar 30, 2011 | 10:52 AM
d16z6Tcrx's Avatar
Poke a hole in the thermostat. Ull still retain heat but the car will cool down faster. I do that to all my turbo street cars and I also run the stock fan plus a pusher fan in front. I turn the pusher fan on in the burn out box then off. Then again on the return road after a pass. My temps stay below 200.
Old Mar 30, 2011 | 11:03 AM
akcapr's Avatar
if its clear i dont mind cuttin into the other lane when you have a clear view of no oposing traffic.
Old Mar 30, 2011 | 11:05 AM
akcapr's Avatar
the way my radiator is places its not exposed to frontal air almost at all. any air passing through it passes throug the intercooler first.
Old Mar 30, 2011 | 11:16 AM
DC2 CRUSHER's Avatar
thanks!
I didt read the other replys but install a fan in front of the radiator facing straight at the radiator so a grip of air will go in n the other stock fan leave it alone So more air coming in that works for us in the AZ HEAT 2 fans!!!
Old Mar 30, 2011 | 03:01 PM
sp00led's Avatar
Yea, my USDM Integra front is the same way. No airflow is coming in while moving except what goes through the intercooler and condensor first. I've thought about going jdm front just for ventilation and cooling.
Racebum mentioned the general consensus is no half sized radiators on the circuits. I've started to accept that this is probably the faite of my car as well. I'm running a single puller fan on the street and I still have issues in 100F temps after a pull when coming to a stop. I've since added a turbo blanket and I'm thinking about adding a pusher fan before summer. I just doubt it is possible to have a turbo integra with a half size radiator that can get beat on for 20min straight without hitting 220+F
Old Mar 30, 2011 | 03:33 PM
xfrankx's Avatar
at least you had a drift wheel for that crazy backroad run....
low temp thermostat and get a puller fan. world of difference
Old Mar 30, 2011 | 03:56 PM
AlexDphoto's Avatar
Im interested in the same thing. My setup consists of a mishimoto half size radiator triple core with a FAL puller fan. Was thinking of adding in a spal pusher as well. Turbo blanket will also be apart of this.
