b16 tranny problem in 5th
Old Mar 29, 2011 | 11:49 AM
titi_vtec's Avatar
Default b16 tranny problem in 5th
i open my tranny just before making my swap and i swich everything that where wrom inside of it, i put a lot of new stuff in it and i put oil in it, later on my dad accidentally take out one nut and i leak like almost 1/4 of a botter of oil, and my 5th gear when am driving and u let go the gas i came out? what is causing this? i need oil? and also when i put 1st and i let go the clutch slowly it feels like if jumping? comment pls
Old Mar 29, 2011 | 11:54 AM
grumblemarc's Avatar
The Grumpiest
Default Re: b16 tranny problem in 5th
So it only did this AFTER you swapped out parts?
Old Mar 29, 2011 | 11:58 AM
titi_vtec's Avatar
nop i never have it before and i open it and i put everything on it new and i were sure that every sincro and gear were good, i just put the swap, oil, it leak, no put more oil, and is doing this
Old Mar 29, 2011 | 12:01 PM
The Grumpiest
Take it back apart and retrace your steps. I'm going to say that something definitely did not get put together properly.
Old Mar 29, 2011 | 12:05 PM
titi_vtec's Avatar
i will see because you can put 5 and it run normal no always the gear come out but 2 from 6 time it does, so i will see if i can fix this againg i took it to a shop and they did for me
Old Mar 29, 2011 | 12:36 PM
hyperblu's Avatar
You're post is extremely hard to understand...
Old Mar 29, 2011 | 12:42 PM
eksedan98's Avatar
I had a similar problem in mine when i swaped my motor and tranny. When i was driving in fifth gear the tranny would just pop out of gear. I though I had a busted tranny but all it needed was some more tranny fluid because it was very low on oil and after I refilled it, it ran smooth from there on.
Old Mar 29, 2011 | 01:27 PM
94EG8's Avatar
Seagull Management
popping out of 5th is usually a sign of low fluid. If you keep running it like that it'll start to burn gears and eventually they'll start welding themselves to mainshaft.
Old Mar 29, 2011 | 04:54 PM
titi_vtec's Avatar
thanks so i will put more fluid so thanks
95jdmcivic
Nov 6, 2009 08:14 PM
raytownracer
Jan 26, 2009 05:20 AM
meagainsttheworld
11
Aug 29, 2006 11:55 PM
ShadowJester
12
Sep 27, 2005 03:19 AM
