Steering problems.
Old Mar 29, 2011 | 08:42 AM
Skahuler's Avatar
Default Steering problems.
From a much-older thread..
Originally Posted by yakitori
i recently bought a 1992 hatchback and at a dead stop the steering wheel feels a little loose (there is no play in the steering) just feels loose. at high speeds say on the freeway the steering feels really loose in the middle. at normal speeds on the streets when the steering wheel is at 12o'clock the steering wheel seems to have a weird play to it. I recently got an alignment and he said it wasn't off by much. he sugested changing the tires so I did and I still have the same problem is the civic dx steering ratio different than the other models? also my friend has the same problem with his 97 dx coupe
Having the same problem 95 Honda civic ever find out what was wrong? .. if so How did you fix?
Last edited by It Wasn't Me; Mar 29, 2011 at 11:30 AM. Reason: Moved into its own thread.
Old Mar 29, 2011 | 09:29 AM
NOYGDB's Avatar
Default Re: steering problems
Sounds like something binding up. Or maby even possibly something with the power steering? Do you have a hose kinked up? Hows the fluid level? Fluid ever been changed?
Old Mar 29, 2011 | 09:30 AM
grumblemarc's Avatar
The Grumpiest
This is a 7 year old thread.
Old Mar 29, 2011 | 09:40 AM
NOYGDB's Avatar
wow, didnt notice that..... lol just saw it at the top of the list.
Old Mar 29, 2011 | 12:02 PM
Skahuler's Avatar
Default Re: Steering problems.
Old post But my car is having this problem - I have 182,000 miles on my 95 honda civic DX manual Steering .. I drove up to Boston from NY with out a problem , while coming back I pulled in to a rest area and found that my steering felt loose pulling into a space.. before if I turned into a spot I would have to turn the steering wheel 1/4 turn . now I have to turn the steering wheel more 360 degrees ( as if a Gear ratio had changed) - wheels still move left and right together.. I have replaced both inner and outer tie rod ends and had just gotten an alignment before my trip and there is no clicking sound or shaking when drive - drove over 100 miles on the highway after this cause I had to get home. - Does anyone think If tightening the Rack guide screw would fix this , I was thinking maybe the spring in the Rack guide screw has gone bad cause of the sudden looseness . is that even possible ...or did my steering rack just crap the bed .... I hope not .. thank you
Old Mar 29, 2011 | 12:04 PM
Skahuler's Avatar
One more thing there's no play in the steering it just has a turning ratio problem I think
Mishako129
May 11, 2013 01:06 AM
sebringap1
Oct 11, 2007 08:40 PM
tintin11
Aug 5, 2003 03:15 PM
Soulless
Dec 31, 2002 01:36 PM
