Transmission & Drivetrain Gearboxes, Differentials, Clutches
Sticky/non-disengaging clutch and grinding while in gear
Old Mar 29, 2011 | 10:50 AM
CAVTECSol's Avatar
Icon2 Sticky/non-disengaging clutch and grinding while in gear
Recently I noticed a couple of symptoms in my del Sol VTEC (b16a3). The clutch pedal movement no longer has a smooth/consistent feel. Also, under moderate/heavy acceleration, the clutch will not disengage when the pedal is pushed to the floor.
Along with the clutch problems, I hear a soft grinding noise coming from the transmission while the car is 1)in motion, 2) clutch is pressed/disengaged and 3) the stick is in a gear.
Any ideas?
Thanks
Old Mar 29, 2011 | 11:06 AM
CEPerformance's Avatar
Default Re: Sticky/non-disengaging clutch and grinding while in gear
Any ideas?
Thanks
I had something similar happen to a customers car.
Pulled it apart and found the flywheel bolts had backed out and were rubbing the clutch disk...
Best way to find out would be drop the transmission and pull the clutch.
Before that try changing the transmission oil.
-Sean
Old Mar 29, 2011 | 12:53 PM
CAVTECSol's Avatar
Icon2 Re: Sticky/non-disengaging clutch and grinding while in gear
Why would I only hear the grinding when the gear selector is in a gear though?
dexy
Jan 11, 2005 09:53 AM
TylerC
Jan 13, 2004 01:25 PM
integra81
Mar 11, 2002 07:43 AM
