keep hydro gsr trans or use 91 ls trans?
Old Mar 28, 2011 | 11:28 PM
hatchet_honda's Avatar
Default keep hydro gsr trans or use 91 ls trans?
im putting another b16 together to put into my 91 dx hatch. right now it has a 95 gsr hydro trans with the hasport adapter. i picked up an ls cable trans from a 91 integra. im stuck on which to use this time around.
id have to buy a diff clutch disc and trans mount if i used the cable trans but i didnt really like the release with the hasport cable/hydro setup. whar to do..any input?
Old Mar 29, 2011 | 06:42 AM
tonythetuner®'s Avatar
Default Re: keep hydro gsr trans or use 91 ls trans?
I'm using a hydro b16 trans in my ef with a ls swap for now.. the clutch pedal is pretty stiff and its a stock clutch but it feels like its a after market clutch lol. and also the adjustment on the cable to hydro accuator is pretty pickey but I got it dialed in right where I want it now. it took like a half hour of playing with the adjustments to get the clutch to engauge and disengauge right...
Old Mar 29, 2011 | 11:20 AM
Ass$nyper's Avatar
Pirate General...YARRRR
Different gears are what makes this a easy pick.
I'm not a huge fan of the feel of the hasport setup (while it's a great engineered piece).
I rather a cable, but not an LS.
You also can convert to full hydro kits are out there. Hydro parts are easier to comeby.
Old Mar 29, 2011 | 11:21 AM
KINGVEM^^ED6's Avatar
b16 with a ls tranny is **** bro
Old Mar 29, 2011 | 07:44 PM
well id rather not spend the money for another clutch aand another mount when i have both these parts brand new already. and id be sooper pissed if this ls trans has shifting problems after install. least i know the gsr trans works perfectly. ill just deal with the hasport setup and possibly ponder whether to attampt the full hydro conversion
Old Mar 30, 2011 | 05:55 AM
I have the innovative cable to hydro accuator and it was real picky at first. till I took the time to mess with it but once its set right it feels normal besides the stiffer pedal feel. All I need to finish my car is to get the innovative hydro mount for the trans. I'm kinda in the same situation your in. I have a cable trans mount but I'm using a hydro trans lol. And also about changing clutch disk you don't have to unless the cable ls trans is out of a 92-93. If its a 90-91 you will have to change the clutch disk tho
Old Mar 30, 2011 | 05:58 AM
Boosted Chemist's Avatar
get a hydrobracket and install a cmc, i think a few companies make them now.
tooslohatch
Transmission & Drivetrain
Sep 29, 2014 07:27 AM
gsr_b20b
Sep 4, 2012 05:04 PM
AllMotorAri
Aug 14, 2012 10:16 AM
wreckeddc4
Oct 5, 2011 02:26 AM
b20vtec91DA
May 31, 2009 06:00 AM
