95 Civic Hatch starting problem
Old Mar 28, 2011 | 08:27 PM
soNNy638's Avatar
Default 95 Civic Hatch starting problem
So as I was waiting for a light to turn green, I stalled out my car and when I tried starting it, the engine would not turn over at all. All lights including interior lights, audio, headlights, taillights all work, but why won't the engine turn over?! SOMEBODY HELP
Old Mar 28, 2011 | 08:31 PM
shogee's Avatar
Default Re: 95 Civic Hatch starting problem
Multiple possibilities, ignition switch, nuetral safety switch, battery, starter solenoid, wiring, start with battery, just becaise lights come on does not mean there is enough power for the starter, then check starter
Old Mar 28, 2011 | 08:32 PM
j4s0n1337's Avatar
Is it cranking at all? I'd do a compression test if it cranks.
Is the fuel pump priming? If not check the main relay, they go bad in civic's around that year ALL THE F'ING TIME!
Old Mar 28, 2011 | 08:35 PM
Former User's Avatar
By wouldn't turn over, do you mean the starter motor does not crank the engine?
When you turn the key to ON(II), do you hear the fuel pump prime for 2 seconds? And does the CEL remain on steady or turn off after 2 seconds.
Old Mar 31, 2011 | 01:30 AM
soNNy638's Avatar
Yeah. there's no crank, but I hear the fuel pump prime for 2 seconds.
crx2hatch
Jul 16, 2011 10:13 AM
stl eh2
Dec 3, 2009 10:07 AM
taboo948
May 19, 2008 07:26 AM
tannerLSt
Jan 19, 2008 07:34 PM
Scorch7
10
Oct 19, 2005 06:32 PM
