Transmission & Drivetrain Gearboxes, Differentials, Clutches
5th gear bearing noise?
Old Mar 28, 2011 | 07:48 PM
punkracer's Avatar
Icon2 5th gear bearing noise?
just did ls 5th gear swap in my S80.. making a bearing noise.. what bearing did i f*ck?
also got fluid leak how common are inputshaft seals going? just did axel seals, but, seems to still be leaking... looks like tranny is comming out.. need help diaging the 5th gear noise....
thanks in advance..
Old Mar 28, 2011 | 09:52 PM
Gearspeed-Performance's Avatar
Default Re: 5th gear bearing noise?
Did you put new bearings in when you did the swap? Did you use a matched set of 5th gears? New 5th gears? It would be a good idea to replace the input shaft seal, shift shaft seal, and both axle seals when you have the trans open. I would also change the counter and mainshaft top and bottom bearings if its in your budget...especially since you either have a gear whine or bearing whine.
Old Mar 29, 2011 | 04:17 AM
punkracer's Avatar
how bad is this to drive.. can i get car dyno tuned?
Old Mar 29, 2011 | 05:35 AM
Honda Bull's Avatar
Can it get dyno tuned?
Well. Let's see. It COULD be gear whine rather than bearing noise. If it's bearing noise, it can lead to gear whine down the road if not taken care of.
If you're leaking oil inside the trans housing, you run the risk of getting oil on the clutch. So, you could potentially waste a clutch and need a new one if not addressed now. If this happens, and the tuner's time is wasted, they could charge you - plus, they aren't going to appreciate their wasted time. You also don't know how much is leaking out, so the trans can potentially get run low on oil, leading to gear asperities, etc.
So, you're potentially out a 5th gear, a clutch, and possibly time for a tune that couldn't happen but they had to charge you anyway since your clutch slipped. Think about what you should take care of first.
Old Mar 29, 2011 | 06:50 AM
punkracer's Avatar
10 daY TAGS ON CAR.. gotta dyno tune and emission tune car then i will take care.. leak is slow.. and noise is only in 5th..
Old Mar 29, 2011 | 07:50 PM
Honda Bull's Avatar
Sounds like ya already had your mind made up then and none of our opinions will change that.
Unfortunately, we aren't there in person to see how bad the leak is or how bad the sound is eminating from your transmission. So none of us will be able to say exactly what you're looking at in regards to time frame for failure / if it'll make it / etc.
Online transmission diagnosis is like online engine tuning. The engine tuner cannot see if the owner of the car has their mechanical timing set correctly. They cannot determine what is causing Code 8. They cannot read the plugs or perform a leakdown test at their own discretion. It's just not going to do much good over the internet. Find someone locally that you trust and you can see regarding your transmission, and get their opinion.
kami6666
Feb 25, 2011 12:13 AM
Rooftop voter
Nov 1, 2010 06:54 PM
itsLOUiSduh
Mar 9, 2009 08:35 PM
EK k kay
Apr 8, 2005 08:06 PM
NipponRacing
May 3, 2003 03:09 AM
