89 si w/b20b swap , needle staying on Cold
Old Mar 28, 2011 | 05:22 PM
93grayeg's Avatar
Icon2 89 si w/b20b swap , needle staying on Cold
I have a 89 si w/a b20b , got the motor with 30,xxx miles on it. Car has a Pwr radiator , today the needle started acting weird. When I drive the car it wont come off the Cold mark , as soon as I come to a stop it starts to slowly move up , but then goes back down as I start moving, Car has a slim fan wired to a switch , I keep the fan off most of the time. Sound like a bad thermostat? Im not leaking coolant, The heat blows warm, I tried bleeding the system today and no change , Any ideas? Thanks
Old Mar 28, 2011 | 06:24 PM
KINGVEM^^ED6's Avatar
Default Re: 89 si w/b20b swap , needle staying on Cold
sounds like bad thermo
Old Mar 28, 2011 | 06:31 PM
93grayeg's Avatar
would I still have interior heat with a bad thermostat??
Old Mar 28, 2011 | 07:39 PM
N'viouzEF9's Avatar
my car did the same thing recently change that thermostat
Old Mar 28, 2011 | 09:32 PM
PoneTony's Avatar
i have the same problem on my '94 tempo but i refuse to replace anything else on that piece of crap! i won't even change the oil more than once every 10,000 miles.
Old Mar 28, 2011 | 09:36 PM
93grayeg's Avatar
lol , thats funny. Anyone know If I would still have interior heat if the thermostat was stuck open? I do have heat even though the needle is reading Cold
Old Mar 28, 2011 | 10:05 PM
Funtington777's Avatar
better than at the H mark
I would reccomend new thermo, and yes you will have interior heat with a thermo reading cold...
Old Mar 28, 2011 | 10:48 PM
BiG ChOr!Zo's Avatar
mine fluctuates like this also and i have a nearly new gates thermostat with about 7k on it...as previously stated as long as the heat works and it doesn't overheat don't mess with it if it aint broke...!!!
Old Mar 29, 2011 | 08:44 AM
93grayeg's Avatar
thanks guys , guess im going to try an oem thermostat this weekend, cant think it would be anything else
Old Mar 29, 2011 | 11:12 AM
93grayeg's Avatar
I have been thinking , If the thermostat was stuck open wouldnt I have little or no heat coming from the vents?? I have heat even when the temp is reading cold...?
Old Mar 29, 2011 | 11:13 AM
93grayeg's Avatar
also my idle has been acting funny also??
Old Mar 29, 2011 | 08:21 PM
93grayeg's Avatar
this is driving me crazy , I got a new oem thermostat on the way
Old Mar 29, 2011 | 08:30 PM
Projekt_Ef9's Avatar
It would still blow warm air but it might not be as hot as it used to be if the thermostat is stuck open. It could be wiring to the coolant temp sensor or the sensor itself too.
Old Mar 29, 2011 | 08:42 PM
93grayeg's Avatar
I thought about the sensor but I got this motor with 30,000 miles on it from a jdm engine place, I was thinking maybe because the motor sat with no coolant in it that could have had something to do with the thermostat going bad?
Old Mar 29, 2011 | 08:49 PM
That is very possible but the sensors can go bad. I bought my b18b with 30000 miles and it had a bad oil pressure sensor on it that i had to change. Check for a short in the wire as well since we do drive almost 30 year old cars. My 88 hatch has had so many stupid wiring problems that just popped up out of nowhere.
Old Mar 30, 2011 | 11:14 PM
G. Man's Avatar
It wouldn't be your temp sensor, the temp sensor doesn't have anything to do with your temp gauge. It sends the info to your ecu. It would be the temp sending unit. Temp sensor has two wires going to it, and the sending unit has one. And if your heater is blowing hot air I would bet on the sending unit. If it was your thermostat the air would be noticeably cooler. And I wouldn't think it would fluctuate like that (in my experience). Good luck
Old Mar 31, 2011 | 08:22 AM
93grayeg's Avatar
the temp sensor is the one that plugs into the thermostat correct? Where is the temp sending unit located?
3rdman
Jul 26, 2009 05:29 AM
tianporn
Jun 18, 2005 07:22 PM
technine
22
May 9, 2005 12:47 PM
PreIudeSI
Aug 24, 2004 09:55 PM
crxtreme27
Aug 19, 2002 01:54 PM
