Transmission & Drivetrain Gearboxes, Differentials, Clutches
gsr wont go in gear if u drive for a while :(
Old Mar 28, 2011 | 11:40 AM
allmotorgsr98's Avatar
Default gsr wont go in gear if u drive for a while :(
i having problem with my gsr tranny today yesterday goes in gear smooth no problem waking and drove it around for a bit then it started have problem getting it in gear. if i would to drive it a for a bit and parked on the side it would get stuck and cant go in gear but if u force it it would go in gear and u could shift it to all gear no problem is it my tranny is going out or clucthmaster cylinder/slave cylinder or clutch and pressure plate i havent change my clucth for 3 year and my clucthmaster cylinder is leaking my slave cylinder is queaking when pushing on clucth i know my clucthmaster is bad but it been three year all i did is refilling the clucth fuild nothing wrong in 3 year and now it wont go in car today but if i force it will go in perfect then after that u could go in gear okay but ther whinning noise and grind i think???? help me out please
Old Mar 28, 2011 | 02:42 PM
Honda Bull's Avatar
Default Re: gsr wont go in gear if u drive for a while :(
I have one question. A new master cylinder is like $120 from Honda. Why did you not replace it in the 3 years you've known it to be leaking? Isn't your carpet absolutely soaked with brake fluid? lol
Old Mar 28, 2011 | 03:30 PM
hahaha yeah soak with fluid that what i get for not changing it cuz i dont even know it was it tell last year lol and yes i bought it at autozone is like 37 and slave like 11 buck i just got done fixing it and run like a champ wowo thank for ur help tho good thing it both of those only thought my tranny was gone that would be bad. leak so bad lol and slave cylinder sound like crap it all like rusted and squeaking like hell lol.
Old Mar 28, 2011 | 07:54 PM
Honda Bull's Avatar
Yeah. Sounded like it was definitely going to be a clutch system problem. Your trans should be okay, though it's possible you've added some wear to the shift components in it. Good to hear you got it fixed.
Old May 29, 2011 | 08:21 PM
help me out again my tranny is acting up again today it just wont go in gear when u step on the clutch u could hear grinding noise and like slipping of gearing help me out would it be throw out bearing or is the tranny have bad syncro??
Old May 29, 2011 | 08:34 PM
technic05's Avatar
Hi,
If you're pressing on the clutch and a whirring/whining noise occurs it's usually a throw out bearing issue.
If you're trying to shift into gears and it's grinding that could be a synchro issue. Or when you're pressing on the clutch pedal it's not fully pressing the pressure plate (master or slave cylinder issue.)
I would start with the obvious and go from there. It wouldn't be considered wasting money because if somethings leaking it needs to be fixed. Better to try those first than to drop the trans do a "repair" and the mechanical controls are still faulty.
Old May 29, 2011 | 09:24 PM
yeah i change my slave and master cylinder already it fix it for a while now but when u step on the clutch u could hear whirring and hissing sound. I drove my car for a bit like that then today it finally wont go to gear today again when i put it in reverse it jump backward once and soften the clutch pedal a bit then it wont go in gear at all.
When i turn off the car and put it on first gear and start the car while my foot pressing the clutch all the way it would launch forward then ill brake to kill the car then i started up the car again then it would go back in all gear again. Once in gear most likely it would shift in smoothly but just grinding when u step on the clutch to shift u could here hissing..
I think it the throw out bearing since i havent change my clutch for so long ago maybe like 6 year i think i know it long ..
Old May 30, 2011 | 05:01 AM
technic05's Avatar
It sounds like your clutch is staying attached to the flywheel even though you are pressing on the clutch pedal. I believe you might have a clutch assembly failure all-together. Maybe your pressure plate isn't disengaging the clutch disc completely from the flywheel when you're pressing the pedal which causes the mechanical connection to move the car.
If it was just the throw out bearing it would be just making noises. You might want to invest in a new flywheel/clutch assembly since you have the trans dropped. Good luck man.
Old May 30, 2011 | 11:04 AM
thank for the help yeah ill try a new clutch, pressure plate and flywheel combo all together to see if its the problem thank you
Old Jun 4, 2011 | 09:30 PM
got it fixed lol damn was hard lol first time dropped out my tranny. Run into alots of little problem like rear main seal is leaking oil and the big one lol. The problem that it dont go into gear was that the spring on the clutch disc shot out of the disc and got stuck on the fylwheel. It grinded the flywheel a little and yeah the bad part all the 8 pieces flywheel bolt lol lucky it was not stripped all the way so i manage it get it all out safe and sound glad i got it fix thank you technic05 for your help ill post some pic on what happen lol
Old Jun 5, 2011 | 12:38 AM
this the pic of the disc with the shot out spring that grind all the 8 bolt and flywheel which make me cant shift to no gear take it look when u dont change clutch in 6 year lol.
Old Jun 5, 2011 | 08:51 PM
Mista Bone's Avatar
D Tranny Guru
typical 60k mile B series clutch.....
Old Jun 5, 2011 | 10:25 PM
yeah i drove my car from 98000 mile all the way to 183000 mile now without changing the clutch out so that was my bad
JPerkMr954
15
Apr 28, 2011 02:07 PM
dc2long
Apr 15, 2010 07:43 PM
Djole_V
Feb 12, 2008 10:12 AM
982drLS
Jun 12, 2004 04:44 PM
ludelvr
Sep 19, 2003 05:34 PM
