Real quick ecu question? I searched
Old Mar 28, 2011 | 11:30 AM
Eric Walls's Avatar
Default Real quick ecu question? I searched
I have a 100% original 1988 crx si all stock. Can I swap in a crx HF ecu an see good MPG gains without any bad side effects other then horsepower loss which i dont care about. thanks
Old Mar 28, 2011 | 11:31 AM
KINGVEM^^ED6's Avatar
Default Re: Real quick ecu question? I searched
nope
Old Mar 29, 2011 | 08:28 PM
Eric Walls's Avatar
Originally Posted by KINGVEM^^ED6
nope
elaborate plz.
Old Mar 29, 2011 | 08:49 PM
k20rex's Avatar
Quick google search to make sure but here it is; same pinouts on both ecu but hf has a egr valve, si has fast idle control, hf has lower rev limiter
Old Mar 29, 2011 | 09:12 PM
BrandonR's Avatar
HF ecu will do more damage then good. It will run lean and trip check engine light for EGR valve. Best just to stick with your PM6. If you want better mileage, get an HF tranny. LONG gears for the highway.
Old Mar 31, 2011 | 03:17 AM
Yellow EF8's Avatar
If i were you i would rather swap a HF tranny up the tire pressure and do a sparkplug and sparkplug wire change this will help you save gas. good luck
Old Mar 31, 2011 | 11:58 AM
Ass$nyper's Avatar
Pirate General...YARRRR
Correct.
Swapping in the ECU from an HF will "work" as far as it'll fit on and function but it's not setup to run the motor you have on it. It won't be happy.
Using the HF trans will net you better milage, at the cost of any kind of acceleration.
Old Mar 31, 2011 | 12:05 PM
Originally Posted by Eric Walls
elaborate plz.
no need to the ansrs NO
Old Mar 31, 2011 | 12:08 PM
Ass$nyper's Avatar
Awful reply.
He asked a VERY valid question.
Do not shoot someone down for wishing to educate themselves.
He wanted to know why something wouldn't work on a technical level, you bash him for that? Find the log out button. Absurd. You come to a tech site and mock people for wanting to understand tech?
Old Mar 31, 2011 | 12:11 PM
a no is a no bro
Old Mar 31, 2011 | 12:13 PM
Ass$nyper's Avatar
a no is a no bro
:facepalm:
It does work, as it's been explained, it's just not a good idea.
So really you are incorrect and spreading bad information by over simplifying it. Do you see my issue with your post now?
Also "Why not?" is a very legit question. He now has an understanding of the map on the HF's ECU vs his stock PM6.
Old Mar 31, 2011 | 12:16 PM
Old Apr 1, 2011 | 06:58 PM
Eric Walls's Avatar
Thanks to the ppl who actually provide me with useful n helpful info on the ecu. Ill be swaping in an hf ecu along with fresh clutch an flywheel next weekend.................../in turn ill be selling my minty grind free si tranny so keep a look out in the fs: thread.
OH BTW IM NOT A NEWB...........I forgot my login info an had to start another account.
Current EK civic build below, GSR 2.0L darton sleeved block precision GT40 4" DP Hondata s300 etc: 571whp 406wtq @27lbs. 10k.rpm redline.
Old Apr 1, 2011 | 07:01 PM
lol nice
Old Apr 1, 2011 | 09:20 PM
BrandonR's Avatar
Nice build. You'd think with the know-how to build that you'd have enough sense to understand the HF ecu on your D16A6 is a bad idea. Good luck bro. -Later, BR
ef yu
Nov 17, 2010 04:49 PM
cbrman
Feb 24, 2005 09:43 AM
Tyson
Aug 10, 2004 12:50 PM
CRX A4
13
Feb 7, 2003 06:01 PM
IamVtec
Aug 29, 2002 09:58 PM
