EP3 Fog Light problem
Hi guys!
I'm just in the middle of putting the fog lights on my EP3 (Type R 2003) and I have this small problem, everything is hooked up as it should be (at least I think so) but there is one brown contact left over that I just can't figure out where to put. The contact is brown, has a red wire and has a note on it that says 'Lgnition'. Anybody that knows the answer?
Picture:
The fog light kit is the one that you can buy from showoffimports/password:jdm: http://www.showoffimports.nl/product...roductid=31351
Picture:
Hi guys!
Picture:
[IMG]http://img25.imageshack.us/img25/3139/iphone002l.jpg[/IM]
Picture:
I just hard wired mine tho.
The contact that was next to the battery was the same as the one I was going to put in it so that won't work. But I found a contact that could be the right one, it was just next to the gas pedal and had blue tape so I tried that one out but still no luck, don't know if it is the right one/wrong one or if it's something else in the system that's screwing things up.
The contact that I found:
If anything else doesn't work I'll have to try that. Any link to a DIY?
Yes it's grounded, the red one is connected to the brown contact which I put in the other brown contact that I found (picture above). The yellow one is connected to it's other part which leads to the fog lights, but because the two yellow ends couldn't reach each other I had to extend it and I used an old cable that I found in the garage, maybe it's the cable that's bad? If it's not the cable I think it may be one of the grounds or maybe some of the extensions that I had to do on the other cables.
PROGRESS!! Cut the brown contact off the cable and then extended it and put it on the + on the battery, 'hallelujah-moment it works'! :D Now there's just this smaaall problem, I'm guessing that the cable gets elektricity 24/7 because the button for the fog lights is glowing even when the keys isn't in, when you push it - the fog lights come on and the button starts glowing even brighter (you can do this without the keys in the car). My question now is if you can have it like this without having problems with a discharged battery the day after? or will it take too much elektricity so you won't be able to have the car standing in the garage for a week or so without having to charge the battery?
button when the car's turned off and no keys in
It shouldn't be lit up 24/7.. you need to connect that wire to a switched 12v source so it only turns on with the ignition. Otherwise you'll kill the battery.
I'm thinking of connecting the cable to one of the free slots in the fusebox under the steering wheel, does anybody know which slot that's a switched 12v source? At least on of them should be a switched one. Going to use an add-a-circuit but first just try with putting the cable on the slot to see if it works.
